Uh oh - Limp mode. Added some Octane boost (just used the STP Stuff), and then topped off with more 93 octane about 2 gallons (tank was full). Drove for about 40 minutes and car seemed to run better and knock seemed to go away.. Then stopped for about 10 mins to pick up lunch...came out started car and all was good...pulled out to busy street and went into limp mode - no throttle at all...just idle. JB4 was disconnected and would not connect. Messed with the JB4 under the hood a bit and it connected but still full limp mode - no throttle whatsoever. Then I disconnected JB4 from OBD port and turbos and car seemed to start and rev until i put it in drive. Then was drive-able limp mode - about 2500 RPM and shift gears. Car threw CEL but I could not get JB4 to read it before I disconnected it. Any ideas? Will the car go back to normal mode if I let it sit or do I have to clear the code?
