Nice. Have fun. The only somewhat "special" tools you will need are
hose pinch clamps (2), however, I just used vice grips! And, a
fluid extractor like a turkey baster or similar - I used a medical syringe (Mom used to be a nurse). And, lastly, maybe
long needle nose pliers. No one step was too hard but if I had to say a step was the hardest, it was getting the passenger side of the new tank down onto the OEM hose (no slack in the hose). This is where they give you the new worm clamp but, like I said, long needle nose pliers will allow you to re-use the OEM squeeze clamp, if you choose. AMS instructions are perfectly sufficient but you can watch
MWH's YouTube vid first if you want. Don't be too impressed with how much more fluid this new tank holds, it's not much of an increase at all. Also, I have a much harder time putting on the radiator caps now. Also, without being able to see the fluid levels from the outside, you'll need a flashlight and also some sort of makeshift dipstick. I took a wooden dowel and made a Sharpie line two inches from the edge to make sure the fluid was two inches in depth, as required. But, it looks perty!!!
Enjoy!
