Timing (Ign1) has the normal curve through RPM band. AFR looks good but a little on the rich side (normal for Q50/60). Only concern would be that trims are maxing (value of 44). Fuel wires would help lean out the AFR a bit and maybe bring your trims down a little. I would hook them up if you have them. I would not go above map 3 at this time. Keep logging and see how the car adapts.
FYI - I am looking at the 1st pull on the graph. 2nd one has a gear shift or 2 and is too short to evaluate. Most important values - Ign1 - looks perfect in your pull. It would be ok if values were lower by a bit...key is it is that smooth curve without any large drops (except at gear shift it generally goes to zero). AFR should settle in at high 10, low 11 if you don't have fuel wires...with fuel wires it will be around 12. Trims value of 44 means its maxing out fuel delivery and trying to make AFR richer. OK to see a max value, but ideally you would want to see it move up and down. This means it has enough delivery capacity to get to the target AFR commanded by the ECU tune. Only concern is that the trims are maxed for extended period early in the pull. AFR generally stays lean until the turbos spool up so its not unusual to see higher AFR early in the pull.
