1 - 7 of 7 Posts
Can someone please tell me what torque/HP am I getting on the silversport q60 2019 with a JB4 plug and play at 3PSI?
Thanks
Not enough! Up that bad boy well beyond 3PSI if you have a Sport!
Thanks
An SS w/JB4 @ 3 PSI using 93 octane fuel will put you at about 332 HP at the wheels with 340 torque.
You can push that up to 5 PSI with no problem and that will produce 355 HP/375 torque and at 6 PSI 369 HP/392 torque.
Do monitor your data logs for proper AFR and ignition timing to make sure you aren't over-doing it.
An SS w/JB4 @ 3 PSI using 93 octane fuel will put you at about 332 HP at the crank with 340 torque.
You mean at the wheels, right?
You forgot to correct wheel torque (WTQ) ;)
332 HP at the wheels with 340 torque means the same thing but I hear what you're saying.
1 - 7 of 7 Posts
