Basically I am looking for what temps are the safe zone to go wot with summer approaching.
I know the trans temp is the intercooler temp on the jb4 app. At what temp will the car start to pull timing or is showing heat soak of the turbos? I read to stay below 150 but want to make sure that’s true.
Also, at what water temp will the jb4 cut out (cold range not warmed up) and again start pulling timing on the hot range?
thanks for the info.
