1 - 4 of 4 Posts
2014 Infiniti Q50 base
So i just added isr test pipes to my q50 that also had a Stillen CBE. I was hoping that the exhaust system would eat up most of the rasp but that wasn’t the case. Still a noob to most mods but I was researching how I can add resonators to reduce the rasp. But could i add those to the exhaust system? What do you guys recommend? Thanks for reading
SW New Hampshire
It's a 3.7 so you don't have turbos to act like mufflers. Does the Stillen CBE have resonated mid-pipes? If not I would add them and see if that helps. I would go with at least 14" resonators. A GOOD muffler shop should be able to set you up with Stainless Steel resonators..make sure they use T-304 SS and the correct SS wire to weild it with so it doesn't rust.
Murrieta, CA, USA
I have a 3.0t and had a resonatorless Stillen CB and it was fine. Stuck on LDPs and drone. :( I put in one resonator between the Y pipe and the mufflers. It helped 85%. The shop left enough room to add one more reso if I want it. I think I will eventually do it. This has turned my $1000 CBE into a $1400 one. Live and learn. If I had to do it all over, I'd get the Invidia Gemini which has resonators in it, for $900.
Reactions: Jonjostar
Hey bro, did you get a cel? If yes or no, can you please explain either what you did to not get it in the first place? Or what you did to get rid of it when it came on? Thanks bro🤙🏼
1 - 4 of 4 Posts
