Dear Q50 Org.
This is my first post and I am sharing the solution to a problem I had so all can benefit from it.
I had Key System Fault and Chassis System Control Fault problem
After checking I got Can Comm Problems but it wasn't clear from where
I took it to a good garage.
It turns out that the Trunk Start/Stop battery is very weak and needs to be replaced and that made the BCM go into sleep mode.
The technician reset the BCM and Changed the battery to Varta and it works now!
This is the battery I use. It fits perfectly and is from the best brand Varta.
Thanks
Thanks
