1 - 4 of 4 Posts
Can someone tell me which light bulb led I can put on my Infiniti Q50 2015 for the brakes
The 2015 Owner's Manual states that the rear combination light already has LEDs for the backup light and the stop/tail/side marker lights. The only non-LED bulb is the turn signal light which uses a WY21W bulb.
Is that what you're referring to? If so, here's one example:
Amazon.com: 7440 LED Turn Signal Light CANBUS Ready, W21W WY21W Anti Hyper Flash LED Bulbs, 36pcs SMD Super Bright Amber Yellow Replacing Signal Bulbs, No Load Resistor Need Blinker Bulbs, Pack of 2: Automotive
Make sure any LED bulb you buy has an anti-hyper flashing load resistor or you'll likely have a problem.
1 - 4 of 4 Posts
