1 - 14 of 14 Posts
Hi everyone I have a 2015 Infiniti q50s and for some reason lately the car keeps going into limp mode. The car was perfectly fine before I recently installed two parts. After those two parts the car keeps going into limp mode and I got the car tuned each time I put on any performance mod. The list of mods I have are as follows before the limp mode issues:
- ART pipes, Megan catless downpipes, muffler delete, stillen oil cooler, stillen transmission cooler
after all of those I tuned the car and it made good power if I'm not mistaken it was around 315whp
a couple months ago I put the following mods on:
- stillen cold air intake, motorydyne intake manifold (M370), stillen lightweight crank pulley
after installing those mods I started getting the limp mode issues. I will be driving and all of a sudden the car feels like it loses most of its power. I have to turn the car off and then it starts working fine. Recently I cleaned my MAFS (mass air flow sensors) and that helped the issue greatly but here and there the car still goes into limp mode. I have taken it to my tuner a few times and he can't seem to find the issue and he's even sent the tune to uprev (thats the tune I'm using) and they haven't been able to figure out anything either. They have tried changing a lot of things in the tune but still the car will go into limp mode. Has anyone else experienced anything similar to that or if they can recommend anything to fix the issue.
I read about Stillen air intakes being a huge issue. My bet is for that. Others interested and in the know on our cars intakes will chime in. That's my guess though.
There is your problem right there.
Im not so sure about that as its a NA car. If the MAF readings were off, he would have a CEL.
I don't think it has to do with the missing cats. I have had that mod for almost a year and no issues. Only started happening once I installed the intakes and intake manifold.
If you have an OBD2 reader, try looking for pending codes. Make sure the intake manifold has no leaks and all connectors are secured.
Hi. I have a 2014 q50 3.7 and I recently bought the sr5 cat less test pipes with resonator and got them installed, im a tech myself. And the check engine light came on which I spected that. But now the car is going on limp mode, looses all the power. Any idea what I can do. I just had this done a few days ago so I haven’t tuned it with no one. Any idea what I can do. Thanks
Might be a feul pump/flow issue. I just got my car tunes 3 weeks ago and my car went into limp mode today for the first time. So it's the tune or feul flow issues after the tune. I will wait and see of it happens again before I call my tuner. Anyone with info can chime in
Font Art Illustration History Supernatural creature
Reactions: jmalone1224
On a serious note: welcome to the forum. You should start a thread in the new members section telling us about your car!
1 - 14 of 14 Posts
