I have found while going through a lot full of these that many of them are coming with random mileage intervals. The PDI training we went through skipped one of the maintenance indicators (there are actually two). I have been trying to inform everyone possible about this but I suspect many owner are going to find random service interval reminders popping up between 4 and 7 thousand miles.
To reset the indicator, or set the combination meter gauge to the proper 5K interval, for oil and tire. I typically only set either oil or oil filter, they are replaced in pair so there is no need for extra reminders.
SETTINGS --> METER --> MAINTENANCE -->
From here you should see a map with sliding points.
The Maintenance Note section will bring you into the sub menu that will display on the main screens.
There are several options for maintenance reminders, in this system you can really have as much, or as few as you prefer.
