Appreciate it, fuel wires going on this weekend. Glad to hear as this is the first pull with anything over +4, using +5 psi at 4000rpm only - which still seems like a sin for an RS. Log says im barely touching 17.0psi though, could my ‘pedal’ dipping to 96 briefly cause that? ThanksFuel trims didn't max out. ign1 looks good. You might consider installing the fuel wires as your AFR is a little rich at the top end. Otherwise, appears ok to me.
