its a 2 step launch control box. its most often used for manual transmission vehicles to assist in shifting and when theyre equipped with turbkis, to help hold boost between shifts. it can also be used to assist in spooling a turbo from a dig by holding a set rpm at launch.
for an auto equipped vehicle, its use is maximized when using a trans brake. between the two, you can infinitely vary launch rpm and boost.
in my opinion, i think there is something more beneficial before resorting to wiring in a bunch of extra stuff. anyone, literally anyone, needs to crack the TCM to allow full control over the trans. according to the FSM, the oem converter has a 3,300 - 3,600 rpm stall. in practice, ive never seen anything remotely approaching that rpm in any kind of gear and engine load. allowing the transmission to reach full stall from a dig would be a boon for ETs and truly punish DRs and slicks from a first gear launch. additionally, full TCM control would also allow for second gear starts where you could not only have full boost from a stop but immediately have a heavy load on the engine to allow the turbos to stay in boost during low gears.
i fully believe that theres AT_LEAST half a second to be gained from that kind of setup. not only that, running the converter unlocked in low gears would save wear n tear on the lock up before it eventually gives up the ghost, lol. at that point, im calling PTC, Circle D, or even COAN. if im going to pay through the nose for something, its going to be due to quality, not because of greedy people attempting to take advantage of others as is all too common in the import world.
