1 - 20 of 30 Posts
May have found a new bug. Within Infiniti Connection on the lower touch screen, my list of destinations sent from Google (not the ones sent through the Infiniti website) will not scroll to the second page. It shows 1/2 on the bottom, but the buttons on the right side of the screen to scroll down are ghosted.
There also appears to be no way to delete items in this list.
Anyone else seeing this? Any ideas? A new bug?
Thanks.
Thanks.
You know, I think I had that problem last week, but forgot to investigate further. I will check on my drive home from work today and if I can duplicate, I'll report to the engineers.
If you guys are checking, I came across another one that perhaps you can check up on.
Once I set a destination in my navigation (in my case, I looked for nearby restaurants and picked one at random) and the navigation start giving directions. I drive a bit. i then go in to options and go to cancel destination, and the navigation still continues giving me directions. I tried both canceling via the steering buttons on the navigation top screen, as well as through the InTouch screen. in both case, even when i press cancel, the system still continues giving me route directions.
How do you send directions without using Infiniti Connection?
Google maps (on computer, not iPhone at least). Click on the little red icon, more, send, to car and then you indicate Infiniti and your Infiniti Connection email address. There is also an iPhone app that works as a work around.
Works great....except I can now only access the first page worth of sent destinations.
Did they test this software at all?!
I'll check it out...Thank you for the instructions
I do not see a little red icon using Google maps on my laptop. Can you give more specific instructions please? Also, does this work on the new google maps or classic google maps only? Thanks!!
It doesn't work in the new google maps.
Wow that sucks!
I just tested it on my Q50, no problem. I can scroll up or down from 3 pages on my "Turn Lists".
Tested this one too, no problem. Picked a restaurant, drove it on the opposite direction for a couple of miles, than press cancel destination on the Intouch. Navigation cancelled.
Yeah I can't scroll onto page two. I sent 7 destinations and I can only see the first 5.
I think I figured it out how it work. It only stored a total of 6 destination. It only display 5 on the screen and yes I can scroll down to see the 6 destination.
You can't delete it manually (maybe there is a way, but I just can't find out how)
As you add more destination in, it remove one at a time from what on the list.
I record it on my camera. If you guys wants to see it, I'll see if I can post it.
I would like to see it....
Where did you find your Infiniti Connection email address?
1 - 20 of 30 Posts
