1 - 20 of 33 Posts
Rochester, NY
I took advantage of the “buy 3 get 1 for a dollar” tire deal from Infiniti as an excuse to ditch the run flats and get new wheels and tires. Wheels are ESR RF2 18x8.5 ET 30 in graphite and tires are Conti DWS 6 plus 245/45/18. Loving the new look. It sits almost flush - probably as far out as I want to go. I debated about 18 vs 19 inch but since I intend to keep these on year round, given that the pot holes and roads in the winter can get pretty bad, I wanted a little extra cushion with the 18 inch sidewall. And yes, it would look better lowered but that’s something I don’t want to do.
There are two negatives, though. These new wheels cover less of the brakes than the OEM wheels which mean the ugly non-sport brakes show through! A brake upgrade might be in my future. And secondly, as mentioned above, the wheels/tires are more flush (by design) than the OEM setup so mudflaps are probably a good idea. Too bad the OEM ones don’t extend very far out but I guess they are better than nothing?
Tire Wheel Vehicle Automotive tire Hood
Wheel Tire Plant Vehicle Sky
looks great! dont worry about the brakes, you care far more than anyone else. its not like someone is going to publicly shame you over them. ive viewed the oem mudflaps as mainly an aesthetic mod. they have limited practicality due to the body lines, especially the rear.
Reactions: Q50Wolf
Rochester, NY
Thanks. I hear you about the brakes but red calipers sure would look nice against the graphite wheels! Lol.
Rochester, NY
2018 Signature.(sold)
There are two negatives, though. These new wheels cover less of the brakes than the OEM wheels which mean the ugly non-sport brakes show through! A brake upgrade might be in my future. And secondly, as mentioned above, the wheels/tires are more flush (by design) than the OEM setup so mudflaps are probably a good idea. Too bad the OEM ones don’t extend very far out but I guess they are better than nothing? View attachment 112483 View attachment 112491
18" wheels have been my choice on the Q, the are like my Fast FC 04 that I still have.
Will a brake upgrade fit the wheels you got? I’ve read that some 18s clear and some don’t, depending on how concave they are. I’d love to get 18s for mine, but I also want 6 pot front and 4 pot rear calipers, so I think I have to get larger discs which will probably make 18s impossible for me.
Rochester, NY
Good question. I'm not sure. I'd have to find a way to figure that out first. No hurry though, it's not something I would do any time soon.
Here's a short discussion on that very subject. It looks like some of the OEM 18 inch will work:
Reactions: SkylineDreamz
I guess I’m too demanding, but OEM wheels won’t do it for me unless I get them rebarreled for more offset… at which point I should just order custom wheels from stance. Which I would consider… if I could find a guarantee that they’ll clear a massive break set up….. or just accept that 19’ wheels are my most economical option lol. I hate compromising.
Reactions: Q50Wolf
Rochester, NY
Discussion Starter · #9 ·
At some point, if I get serious about a brake upgrade, I could measure the current clearance with the stock non-sport calipers (seems like there is a lot) and if I had dimensions of the Akebonos I might be able to determine if they would fit.
Rochester, NY
Discussion Starter · #10 ·
Did a quick search and I came across a few folks using aftermarket 18 inch wheels for winter with Akebono brakes. So there is an existence proof. However, as you mention, I’m sure it depends on the particular wheel offset/concavity.
Yeah, should be fine with regard to the barrel ID on an 18" wheel but it's the spokes (and offset) that will determine if they'll work. That part could be said on a 19" or even 20" wheel though.
EDIT - here's my stock RS set-up to show how much room is left between caliper and barrel
Front
Wheel Tire Vehicle Car Automotive tire
Wheel Tire Automotive tire Hubcap Tread
Rear
Tire Wheel Vehicle Automotive tail & brake light Car
Tire Wheel Automotive tire Car Synthetic rubber
Rochester, NY
Discussion Starter · #12 ·
I know the the same wheels in 19x8.5 ET 30 (same offset) clear the Akebonos as @dal3_gribble had these wheels upgraded with the BBK. So maybe my 18x8.5 ET 30 might as well.
I'm running 18 x 8.5, +38 in the winter. Not a lot of spoke and barrel clearance, but enough.
Automotive lighting Hood Vehicle Motor vehicle Automotive design
Motor vehicle Automotive lighting Hood Automotive tire Automotive design
Rochester, NY
Discussion Starter · #14 ·
Reactions: mapleDom
Reactions: Pillboy
Sharp, looking there Pill, newer now, then when you bought it. When I had the 18x10 on my car there was more space.
LOL, those pics are from when the car was 6 months old in the fall of 2018.
I'm sure it still looks the same now.;)
A little over 18k miles...almost worn out.
I figure if I don't drive it much the block will remain non-porous and the turbos shouldn't fail and the blend door actuator should still work and the DCU's SD card won't fail.
Basically I'm afraid to drive it.
These are my hopes also but I'm at 27K miles. I feel like the clouds of doom are closing in on me.
1 - 20 of 33 Posts
