No Going Back Now... Z1 Turbos • Z1 LSD • CZP DS • Depo Racing 3” FDPs + AAM 3” CBE • Spool FX-180 + FlexFuel • & MORE!
69002 Views 795 Replies 43 Participants Last post by  DailyQ50
I can’t wait for AMS’s Turbo Kit anymore. After kicking tires for a while and a sh!t load of research... I finally did it! I have placed multiple orders on a bunch of parts to hopefully end my quest for more power and to complete my build. My build will be on stock engine internals and stock tranny (depending on how my car performs on the street and at the drag strip, i might get Z1’s LSD in the future). I’m shooting for a safe (haha) 500 whp / 500 wtq give or take on 91 octane.
PARTS ON ORDER:
•Pure Upgraded Turbos Stage 2
- Ordered directly from Pure Turbos’ website. They retain the OEM turbos’ housing but bore it out and have larger turbine + compressor wheels with upgraded seals. They’re built to order with their quoted lead time of 7 to 10 business days. Edit: Pure’s lead time turned out to actually be 20 business days.
Ordered from Concept Z Performance (CZP):
•CZP by PPE 2.5” Upper Downpipes
- Currently on back order, should receive them in about 3 weeks. Edit: I cancelled this order because there was no guarantee that I'd receive this on time - See 6/22/2020 Edits.
•AMS Low Pressure Fuel Pump (LPFP) - Should receive this in 2 days.
AMS RA338 High Pressure Fuel Pump (HPFP) - Should receive this in 5 days.
•AMS Auxiliary Intercooler Tank - Should receive this in a little over a week. Edit: I cancelled this order because it was "drop shipped" from AMS and it's been almost 2 weeks - See 6/22/2020 Edits.
CURRENT ENGINE MODS:
•Specialty-Z EcuTek E-Tune
- At 19 psi on Shell 91 Octane and have ran this for the past few months.
•Add-W1 Oil Catch Can V3.3 - Got it directly from Add-W1 and have had it on my car for the past few months.
•Fast Intentions Resonated Touring 2.5” Catback Exhaust - Got it directly from FI and have had it on my car since 2017.
Bought from CZP and has been on my car for the past few months:
•Infiniti (AMS) Intakes
•HKS Resonated 2.5” Lower Downpipes
•AMS Heat Exchanger
•CZP Turbosmart Vee Port Pro Blowoff Valves
As you can tell, CZP is my number 1 vendor since they don’t charge tax and are really responsive when it comes to inquiring and ordering parts.
I’m going to install the AMS Auxiliary Intercooler Tank myself as soon as it arrives next week.
Specialty Z is going to install the Pure Turbos, Z1 Upper Downpipes, and AMS HPFP + LPFP, Z1 Motor Mounts, and then dyno tune my car.
EcuTek Tune with the following maps:
•Max psi on VP Racing Q16 - Good for 550 to 575 whp ish, track only
•Max psi on 100 Octane
•20 psi (or max safe psi) on 91 octane
- Good for 500 whp / 500 wtq ish, will be daily driven
•Hot Weather
•Pops & Bangs
If all goes well and if I receive all of my parts on time, I can hopefully get my car into Specialty Z’s shop in about 5 weeks (mid July).
If AMS/Nostrum releases their injectors by then (highly doubt it), I may just add them into the mix too.
I’ll be buying out my lease. My car is currently at 77k miles, so it doesn’t have the factory powertrain warranty any more - this is sorta why I’ve decided to full send it 🏎 🚀
6/22/2020 EDITS:
Ordered from Z1 Motorsports
•Z1 2.5" Upper Downpipes
- They currently have this in stock, so I should receive them in a few days.
•Z1 Urethane Motor Mounts - They currently have this in stock, so I should receive them in a few days.
Ordered from an Infiniti Dealership's Ebay Store:
Infiniti (AMS) Auxiliary Intercooler Tank
- Should receive this in a few days.
7/25/2020 EDITS:
MODS FOR COMPLETED BUILD #1
2017 Q50 Red Sport RWD
Engine
•Specialty-Z EcuTek
Dyno Tune
•Pure Stage 2 Turbos
•Z1 2.5" UDPs
•HKS Res. 2.5” LDPs
•Fast Intentions Res. Touring 2.5” CBE
•AMS Intakes
•AMS LPFP
•AMS RA338 HPFP
•AMS Heat Exchanger
•AMS Aux. Intercooler Tank
•Add-W1 OCC V3.3
•CZP TurboSmart Vee Port Pro BOVs
Wheels/Suspension
Street: MRR FS01 Front 20x8.5 +30 & Rear 20x10 +40 w/ Michelin PS A/S 3+ 255/35 & 285/30
Drag Pack: Front 18x4 +0 Enkei 370Z Spare Wheel w/ 185/50 M&H RaceMaster DRs & Rear 18x9.5 +38 Enkei RPF1 w/ 285/40 Nitto NT05R DRs
•RS-R Down Sus Lowering Springs
•SPC Rear Adjustable Toe Links & Camber Arms
•Z1 Aluminum Rear Subframe Bushing Collars
CLICK FOR DYNO RESULTS OF THIS COMPLETED BUILD ON 91 OCTANE, 100 OCTANE, AND 116 OCTANE
7/26/2020 EDITS
I’ve decided to run Flex Fuel Ethanol on my car with the AMS Flex Fuel Kit. I’ve also enlisted RaceBox to remote tune my car for Flex Fuel Ethanol.
8/1/2020 EDITS:
With this new found power on Flex Fuel Ethanol, my car has started to go sideways a few times at WOT, even in 3rd gear at 60 mph. And, I’ve been spinning and not winning off of the line at the drag strip lol.
So, I’ve placed an order on Z1’s LSD. Since I’ll be installing the LSD myself and will be working in that area, I also placed an order on CZP’s RWD Aluminum Driveshaft and Z1’s RWD Urethane Transmission Mount made for 370Z’s / G37’s. Currently there aren’t any official tranny mounts made for RWD Q50’s / Q60’s. Although the Z1 Tranny Mount isn’t specifically made for the Q50, there have been a few people that have used 370Z / G37 tranny mounts on their Q50’s / Q60’s. I’ll test this out on my car.
9/11/2020 EDITS
MODS FOR COMPLETED BUILD #2
at 79k+ miles
Powertrain/Drivetrain
•RaceBox
EcuTek Remote Tune on E60***
CZP 4” Aluminum Driveshaft***
Z1 LSD***
Z1 Urethane Tranny Mount***
•Z1 2.5" UDPs
•HKS Res. 2.5” LDPs
•AMS Intakes
•AMS LPFP
•AMS RA338 HPFP
AMS Flex Fuel Kit***
•AMS Heat Exchanger
•DeatschWerks DWFF70 10 Micron Fuel Filter***
•Add-W1 OCC V3.3
•Factory Stock Motor
•Factory Stock Tranny
•OEM Injectors
Wheels/Suspension
Street: Michelin PS A/S 3+ 255/35 & 285/30 on MRR FS01 Front 20x8.5 +30mm & Rear 20x10 +40mm
Drag Pack:
Front: 185/50 M&H RaceMaster DRs on 18x4 +0mm Enkei 370Z Spare Wheels
Rears 1: 285/40 Nitto NT05R DRs on 18x9.5 +38mm Enkei RPF1
Rears 2: 325/35 Mickey Thompson ET Street R DRs on 18x11 +56mm ForgeStar D5 w/ Z1 5mm Spacers***
•SPC Rear Toe & Camber Arms
Other
Escort Max 360
Dragy
Braille B129 Lightweight (9.5 lb) Car Battery***
CLICK FOR DYNO RESULTS OF THIS COMPLETED BUILD ON E60 (minus the CZP DS & Z1 LSD)
***Indicates New/Different mods for this Completed Build #2, compared to #1
9/29/2020 EDITS
Since my car is currently at 79.5k miles with the factory motor and factory tranny, I’ve decided to bulletproof my car by building the motor and maybe building the tranny. Additionally, I’ve fallen down the slippery slope of the rabbit hole known as, “MO POWA BABEH!”
I’ve placed orders on the following parts to upgrade my current setup. I’m gonna sell my old parts to recoup some of what I’ve spent.
•3” AAM Resonated FDPs & 3” AAM Resonated CBE. AAM does not keep stock of their FDPs and CBEs for the VR30; they’re made-to-order with a 3-4 week lead time. And, AAM Competition doesn’t list their 3” CBE with resonators. So, since they have to fab their CBEs when customers put in an order anyways, I called them to request that they put in resonators at the mid-pipe section of their CBE; they fulfilled my custom request/order. To get the most out of my PS2 Turbos, opening up the exhaust with a full 3” turbo-back gives MO POWA BABEH!
•DeatschWerks 19S-00-1700-6 Injectors, Spool FX-180 HPFP, OEM Left-Side Fuel Rail 17522-5CA0A, OEM Right-Side Fuel Rail 17521-5CA0A. I’m gonna test out this new, relatively inexpensive (compared to AMS) injector option on full ethanol. More fuel for MO POWA BABEH!
I’m still working out the details of building my motor and maybe building my tranny. If I build the tranny, I’m going to use my builder’s recommended tranny builder (NOT Level 10). This, of course, will enable me to reliably run MO POWA BABEH!
3/5/2021 EDITS:
MODS FOR COMPLETED BUILD #3 (WAS NEVER ACTUALLY COMPLETED)
•RaceBox
EcuTek Remote/Dyno Tune on Full Ethanol***
Built Motor***
~Manley Rods***
~Manley Pistons***
~ARP L19 Head Studs***
Pure Drivetrain Solutions Built 7AT Tranny w/ PDS Triple Billet Disc Torque Converter***
•Killer Chiller
w/ Bypass+Drag Valves***
Z1 LSD
•AAM 3” Resonated FDPs***
•AAM 3” Resonated CBE***
•AMS Intakes
•AMS Heat Exchanger
AMS Flex Fuel Kit
•AMS LPFP
•Spool FX-180 HPFP***
DeatschWerks 19S-00-1700-6 Injectors***
•Add-W1 OCC V3.3
Wheels/Suspension
Drag Pack:
Other
Escort Max 360
Dragy
***Indicates New/Different mods for this Completed Build #3, compared to #2
3/31/2023 EDITS:
Welp… Kris Kunetka / K2 RaceKraft had my car for 2 years with nothing to show for it besides excuses and issues with my engine. WARNING TO ANYONE THAT’S THINKING ABOUT DOING BUSINESS WITH KRIS KUNETKA / K2 RACEKRAFT - DON’T!!! If you get Kris to work on your VR30, then you may end up with an improperly machined head and a major oil leak that’ll drain your oil at 1 quart for every 150 miles driven.
Link to the story here:
MODS FOR COMPLETED BUILD #4(WAS NEVER ACTUALLY COMPLETED)
•RaceBox
Built Motor
~Manley Rods
~Manley Pistons
~OEM Head Bolts***
OEM Factory Red Sport Tranny***
•No Killer Chiller***
Z1 LSD
•AMS Intakes
•AMS Heat Exchanger
AMS Flex Fuel Kit, Version 1
•AMS LPFP
•Spool FX-180 HPFP
•Add-W1 OCC V3.3
Wheels/Suspension
Drag Pack:
Other
Escort Max 360
Dragy
***Indicates New/Different mods for this Completed Build #4, compared to #3
6/2/2023 EDITS:
Welp… Looks like Kris Kunetka’s / K2 RaceKraft’s built motor that he built for me is a dud with a significant amount of metal particles in the lower oil pan.
MODS FOR COMPLETED BUILD #5
•RaceBox
EcuTek Remote Tune on Full Ethanol
•Z1 VRX70 Turbos***
OEM Motor***
Z1 LSD
•Depo Racing 3” 100 Cell Catted FDPs***
•AMS Intakes
•AMS Heat Exchanger
•AMS LPFP
•Spool FX-180 HPFP
•Add-W1 OCC V3.3
Wheels/Suspension
***Indicates New/Different mods for this Completed Build #5, compared to #4
See less See more
Reactions: 5
701 - 720 of 796 Posts
One needs to be careful posting things like that or you could be sued for libel.
Fair. Yeah was just trying to think of the best way to get the word out so no one else gets swindled by K2 "Race Craft". I bet Boost In Motion would cover it on his channel.
This is probably not the best ice breaker on a new forum....
I will clear up a bit of the confusion / speculations.
• Kris / K2 is his own entity. He is not or was ever an UpRev employee. Kris was simply using some shop space we provided for him to work on cars.
• The agreements which we (UpRev & K2Racekraft) had did not come to fruition so we decided it was best for Kris to move out of our shop and continue doing business on his own.
• On January 15th 2023 he was given his formal 60 day notice to vacate the shop so that we could use our shop space for our own R&D projects, bring customer work back into the shop for UpRev to do under our own supervision, business structure and quality control.
  • Helpful
Reactions: 5
Appreciate you guys clearing that up @UpRevSupport. We've always known you guys to be reputable and we know that K2 is it's own entity renting space.
@UpRevSupport
Thank you for the clarification.
Reactions: 1
Gosh man, so sorry @EngineeredQ50 . I feel so bad for you. :cry:
Only an issue if the claim is untrue.
Libel is a tort claim and not subject to the rigors of a criminal claim. I agree with you if written statements made are factual and indisputable. Making disparaging or derogatory statements about someone's reputation or character on FB or public forums can muddy the waters in any civil claim.
It's best to avoid statements like this: "Hopefully! Yeah, he was a “Master Infiniti Tech” at Austin Infiniti before he decided to become a con man."
Just saying...
Reactions: 1
Just saying...
Wonder why there's a plethora of Indians on that list.
Reactions: 1
there is a lot of corruption.
a friend of mine went back home and connected with old friends.
it can cost $100,000 to be a police officer.
I asked why would someone pay that much money to become a police officer and he said because of all the bribes that you're going to get.
  • Wow
Reactions: 1
Until someone thinks you crossed them and you end up dead like those people.
Hoping that K2 stepped up and got your invoice paid to the other shop @EngineeredQ50
Any updates on the new shop getting the car back to a state of being sorted out?
K2 RaceKraft / Kris Kunetka did not step up and did not pay the Invoice from Overkill Performance. Overkill hasn’t heard from Kris since 3/27/2023. I haven’t heard from Kris since 3/10/2023. It is now 4/18/2023.
I dropped my car off at Overkill yesterday. In 2 to 3 weeks from now, Overkill should have more info on the appropriate repair for the the oil leak(s) issue. I’ll update this thread then.
Wheel Automotive parking light Tire Car Sky
I had to park my car in front of the business next to Overkill’s office because all of the parking spaces in front of their office were taken up. Their office and dyno shop is in that building behind that red Dodge Ram. Their repair/work shop is in a building a few buildings away from their office.
See less See more
Reactions: 2
All good bro. I’m hoping Overkill Performance will clean up this mess for me, so I can finally enjoy my car again. A lot has happened since I went down this rabbit hole (since Summer 2020) - Got married and had my first kid among other things. So, yeah, I just want to close out this chapter (Q50 shenanigans) of my life.
Reactions: 5
Dang bro. Sorry to hear that. Hopefully Kris will come to his senses and do the right thing. I would not be able to escape the guilt of doing such a terrible job and mis-managing a project like this, so hopefully he will come around and do what's right.
Congratulations on getting married, and having your first child! But yes, hopefully Overkill can get everything sorted out and you can get on with life, enjoy the car, and have this mess behind you. Hoping for all the best my friend.
Reactions: 2
Nice! Congrats EQ!!
Reactions: 2
While they dropping the motor get those new Z1 turbos installed 🙃
Reactions: 1
Meh. Not trying to put any more money into my car right now.
At this point, I just want my car to be somewhat reliable - especially when it comes to the long block, so I’m hoping Kris did an acceptable job with installing the Manley Piston+Rods along with properly installing all of the rebuild parts - my car did make the 1,770 mile trip from TX back to CA with acceptable cylinder compression test numbers after that trip.
And, I’m hoping to just do basic maintenance external to the long block - like 3k mile OCIs, spark plugs every 3k or 6k miles (will depend on how hard I drive my car and what the spark plugs look like during my oil changes), OCC and fuel filter cleaning every now and then, changing select fluids more often like for my Z1 LSD, maybe having to replace some bolt-on parts that might fail such as the injectors, etc. etc. etc.
I understand that there are a lot of new parts for the VR30 that have came out since I started my build back in the Summer of 2020 (it’s now April 2023).
But, at this time, I’m not trying to be the fastest VR30. If my car turns out to be solid after, say, 10k or 20k miles, then I may go down that rabbit hole again… lol we’ll see.
See less See more
Reactions: 5
What have you been driving @EngineeredQ50?
Wife’s car, stock 2017 Acura TLX SH-AWD. May decide to get a more roomier car since our family has grown and may continue to grow.
Reactions: 4
