The TSB related to alignment of the accessory belt is posted on this site and is NOT exclusive to the "RS version of the 3.0t motor."Update! The Techs said the noise was coming from the drive belt to the AC. They Realigned the AC, replaced the belt and still heard the noise. They then replaced the idler pulley and the noise is not evident. All Warranty work thankfully. They mentioned that there is a Technical Service Bulletin from Nissan on the AC Belt alignment issue with the RS version of the 3.0t motor. The one thing I am still a little concerned about is the pasty mess I found on the Air Filters engine side. The tech said it was normal. So far my car roars down the freeway just like the Japanese Warrior she is. Fast and dangers.![]()
I'm assuming that pasty mess is oil? Under high engine loading, gases from the crankcase don't all pass through the PCV valve but also pass through the blow-by vents that discharge close to the engine side of the air filters.Update! The Techs said the noise was coming from the drive belt to the AC. They Realigned the AC, replaced the belt and still heard the noise. They then replaced the idler pulley and the noise is not evident. All Warranty work thankfully. They mentioned that there is a Technical Service Bulletin from Nissan on the AC Belt alignment issue with the RS version of the 3.0t motor. The one thing I am still a little concerned about is the pasty mess I found on the Air Filters engine side. The tech said it was normal. So far my car roars down the freeway just like the Japanese Warrior she is. Fast and dangers.![]()
That's news to me. Mine aren't oiled either but they are the original filters. I'm about due for new filters so I'll see if they appear to be oiled and if I see any oil accumulation on the engine side.Speaking of oil on air filter, i thought i read somewhere from nissan that factory air filters on RS were oiled while non-RS have dry ones. Not sure how true though, the oem replacement ones i got were dry and part number is the same for all 3.0t trims.
I have 28K miles on her. She was a used car purchase from Car Max. I had been dreaming of owning one for quite some time and the absolute best deal I could find showed up and I bought her. Now my wife is very jealous of my Japanese Girlfriend.Thanks for updating your post. How many miles?
Hi Damonb10. Sorry still a bit of a newb. I was not aware that we had TSBs on here. This great news and good to know. The tech who worked on my car had made that statement about the RS version of the motors. Thanks for the correction.The TSB related to alignment of the accessory belt is posted on this site and is NOT exclusive to the "RS version of the 3.0t motor."
Hi Avedis53. Wow... good to know and makes me feel allot better as I was still a little concerned that the turbos might be leaking oil as some have reported here. I switched the the K & N filters for 2 reasons. 1. I use them in my hobby race cars as they have the best airflow possible. 2. When I pulled out the Nissan Air Filters, they were just high grade paper and nothing special. No Oil.I'm assuming that pasty mess is oil? Under high engine loading, gases from the crankcase don't all pass through the PCV valve but also pass through the blow-by vents that discharge close to the engine side of the air filters.
So it's already been debated and tested that unless you plan on tuning your vehicle, OEM filters will still give the best power for the Vr30. The only benefit of reusable filters on this platform is longevity. When tuned, i think the AMS intake might be the best you can get.Hi Avedis53. Wow... good to know and makes me feel allot better as I was still a little concerned that the turbos might be leaking oil as some have reported here. I switched the the K & N filters for 2 reasons. 1. I use them in my hobby race cars as they have the best airflow possible. 2. When I pulled out the Nissan Air Filters, they were just high grade paper and nothing special. No Oil.
The K & N are up to 3X the cost but as long as you take care of them and wash and oil them, they last a really long time and help the motor breath better.
Is the issue you are referring to about the turbos? If so, the 3.7 isn't turbocharged.This issue seems to be popping up more often these days. Do you have the 3.7? Modifications or just stock? Appreciate your post.
The test data I've seen comparing pressure drops across various dry and oiled filters at increasing volumetric air flow rates doesn't show a significant improvement by using oiled filters vs. quality dry filters (< 0.5 inches H20 pressure drop).Hi Avedis53. Wow... good to know and makes me feel allot better as I was still a little concerned that the turbos might be leaking oil as some have reported here. I switched the the K & N filters for 2 reasons. 1. I use them in my hobby race cars as they have the best airflow possible. 2. When I pulled out the Nissan Air Filters, they were just high grade paper and nothing special. No Oil.
Dang sorry to hear that sir, on a positive note they got you swapped out nice very quickly, Another member had to wait nearly 3 weeks mostlyUpdate:
Got my car back today. They ended up finding oil in both turbos, a leak in the water pump and the belt misaligned.
They replaced the turbos, the water pump, the belt and the AC compressor. The leaky pump and the oil in the turbos worries me the most. If anyone here gets that noise TAKE IT TO THE DEALERSHIP. DO IT.
If the belt were mis-aligned, then the procedure is to re-align it with the AC compressor. Why would they replace the AC compressor?Update:
