This OK to throw in the tank stock?
Time to read. Ill be backWhile octane boosters with MMT are effective - they do have a checkered reputation.
Impact Assessment of Metal-Based Octane Boosters: A Literature Review
dont waste your money. first and foremost, youre not getting 8-10 octane, youre getting octane points. as in, from 93 to 93.8 and thats if you use it with a single gallon of gas. thats why you see that it states "up to" 10 gallons of gas. it doesnt raise 10 gallons of gas 8-10 full octane points, it doesnt even raise 10 full gallons of 93 to 93.8-94. it raises 10 full gallons of gas to anything higher than 93, so 93.1 would still beenough to say "up to".
go to a paint store and ask for 100% pure toluene. its like 114 octane, (R+M)/2. toluene makes up around 30-50% of the gas you already put in your vehicle, it will not hurt anything. i have used it before.
In this case, they advertise 80 points. However, like you say it's "up to" and isn't going to raise an entire tank of gas that high. If it were free and I didn't have cats or O2 sensors, would run it.dont waste your money. first and foremost, youre not getting 8-10 octane, youre getting octane points. as in, from 93 to 93.8 and thats if you use it with a single gallon of gas. thats why you see that it states "up to" 10 gallons of gas. it doesnt raise 10 gallons of gas 8-10 full octane points, it doesnt even raise 10 full gallons of 93 to 93.8-94. it raises 10 full gallons of gas to anything higher than 93, so 93.1 would still beenough to say "up to".
where did you buy it from? You should still be able to return it if you tell them why you cant use it becuase it will foul the spark plugs and it contains MMT which can foul the o2 sensors and you dont wanna run the risk of damaging your car.Well....f%%k me. $23 flushed.
I guess ill use it to start my fire pit a few times and then put the bottle on the shelf in the man cave. 🤷♂️
Thanks guys.
I was ready to post the same about octane points. E.G. getting .8 octane instead of 8 octane points. HOWEVER, there is one company out there that is the real deal....It's not cheap, but it really does boost your octane a significant amount. Obviously you dont use this with a full 20 gallons in the tankdont waste your money. first and foremost, youre not getting 8-10 octane, youre getting octane points. as in, from 93 to 93.8 and thats if you use it with a single gallon of gas. thats why you see that it states "up to" 10 gallons of gas. it doesnt raise 10 gallons of gas 8-10 full octane points, it doesnt even raise 10 full gallons of 93 to 93.8-94. it raises 10 full gallons of gas to anything higher than 93, so 93.1 would still beenough to say "up to".
chock full of MMT, i wouldnt use it.I was ready to post the same about octane points. E.G. getting .8 octane instead of 8 octane points. HOWEVER, there is one company out there that is the real deal....It's not cheap, but it really does boost your octane a significant amount. Obviously you dont use this with a full 20 gallons in the tank.
Oh I get it. Got to pay to play. My point was that while most "octane boosters" are snake oil, there are a few that really do boost octane.chock full of MMT, i wouldnt use it.
uh, yes. the 80s era F1 engines ran ~85% toluene with a filler to get to a specific RON requirement.You serious about the toluene?
I've posted about methylcyclopentadienyl manganese tricarbonyl (MMT) on this forum several times. It's bad news for valves, plugs, O2 sensors, and cats.uh, yes. the 80s era F1 engines ran ~85% toluene with a filler to get to a specific RON requirement.
a gallon of kleen strip (blue and red metal can) should be around $25. if mixing 4 gallons of gas, a 3:1 mixture of toluene and 93 will increase to 98 octane. if you use 91, you need just a little more, 2.8:1.2. to get to 100 octane, you need 2.4:1.6 ratio for 4 gallons total.
compared to E85, its still pretty expensive. then again, a hpfp, lpfp, and injectors are pretty pricey too. if its only for track days, toluene is a good way to go. this is especially true if you can tune your car for it. when you prepare the fuel system and engine for e85, its a much better alternative honestly.
lastly, if you engine isnt knocking of youre not running more boost than can be handled already, using a higher octane fuel doesnt actually help.
Toluene is not to be trifled with. If you're planning on using it, don't allow skin contact and mix it in a well-ventilated area.How much of this magic juice do you use with a full tank - just asking for scientific purposes (😉)
It looks like a can at ACE Hardware is clocking in at @ $24 /gal.
Klean Strip Toluene Solvent 1 gal - Ace Hardware
