81 - 100 of 135 Posts
Same as last time but I did switch my wheels and tires I had these heavy 20 staggered vossens. I switched to a 18x9.5 squared set up with 275/40 firehawks all the way around. Cant wait for cooler weather hope to get mid 11s I try to shift around 6500-7 shifting the whole time no drive
2019 Q50 Luxe RWD
2019 Q50 Luxe RWD
JB4, Fuel Wires, BMS Intakes, AMS LDPs, Frozen Boost 101 HX, E23 fuel
12.68 @ 112mph
Will update with the timeslip when I'm off this work laptop that is locked down tighter than Rikers.. here's the slip in my youtube recap video though https://youtu.be/cP7T796n80A?t=584
2019 Q50 Luxe RWD
Got a dragy, been messing around with it. Trying to find an area where I can do 1/4 runs, but here's a baseline 0-60 for now. Once I aired the tires to 30psi it dropped to 4.69
2019 Q50 Luxe RWD (wish i got AWD so bad now)
Sup guys I just wanted to give an update of my last run of the season, anyway 1st run I did 11.96 @119 mph, 2nd & 3rd was a flop car power lol awd overheat crap and kill power to the car by 4th run I beat my 1st run did 11.95 @118 mph. no new mods was done to the car and all was done on pump gas.
Khris
2017 Q50 Red Sport RWD
  • 72k Miles
  • Specialty Z EcuTek E-Tune on Shell 91 Octane at Max Boost = 1.3 Bar = 19 psi
  • Infiniti (AMS) Intakes
  • HKS Res. 2.5” LDPs
  • FI Res. 2.5” CBE
  • AMS Heat Exchanger
  • Add-W1 OCC V3.3
  • MRR FS01 Front 20x8.5 +30 & Rear 20x10 +40 w/ Michelin PS A/S 3+ 255/35 & 285/30 At 36 PSI
It’s been a loooooong since I’ve gone to the drag strip. I haven’t hit the drag strip since my college days when I had a Prelude H22 VTEC back in the days lol.
Here are the time slips for 2 of my best runs out of 6 runs on the same day at Sacramento Raceway last night. I brake boosted at around 1.5k RPMs during launch in Sport Plus Mode with Traction Control Off and used Automatic Shifting. I wanted my results to be as close as possible to what I’d do out on the street.
12.55 Seconds @ 113.14 MPH
91173
12.514 Seconds @ 113.49 MPH
91174
Next time, I’ll lower my rear tires’ pressures. Anyone have any suggestions on what PSI I should be running my Michelin street tires at? Maybe I’ll get some dedicated drag strip drag radials... Wish I had AWD now lol.
2019 Q50 Luxe RWD
EngineeredQ50 You're probably not hooking very well with those aspect 30 tires I imagine? When I hit he drag strip on 245/40/19 I was at 28psi and seemed to do well. I am getting some 275/40 this weekend so I am looking for some new PRs this spring
2019 Q50 Luxe RWD
#10 - [email protected] - Jonathan Bryant
2018 Q50RS AWD, E30 20PSI tuned by BSTuning, Stage 3 Red Alpha bolts ons with HKS catback system.
Something is way off with this time and these mods... where are you located/what was the DA during this run? e30/20psi should have you running mid 11s in normal conditions
Video I saw was him going 11.5...? You're seeing a red car right.?
What were your 60’ times?
Those 2 runs were with my best launches that day with my street tires at 36 PSI... Although, I’m sure there’s room for improvement as I could hear the tires screeching up until ~10 MPH during those launches. I may run 28 PSI the next time I go.
I got a 2.071 second 60’ time for the 12.55 Seconds @ 113.14 MPH run. And a 2.106 second 60’ time for the 12.514 Seconds @ 113.49 MPH run.
Yup, I can definitely improve my 60’ times.
Drag racing is addicting :cool:
2019 Q50 Luxe RWD
My best hit at the track was 12.68 at 112.81, 60ft was 2.069. Best dragy was a 12.64 @ 114.32. 60ft was 2.15. Dragy run was done in negative DA and traction was minimal but the cold air made a difference in the pickup
Reactions: EngineeredQ50
Do you think we could get our 60’ times down if we ran drag radials (maybe the Nitto NT05R) with lightweight 17’s or 18’s in the Rears? Maybe a 1.8 or 1.9 second 60’ time (which we may be able to shave off 0.2 to 0.4 seconds in the quarter)...?
I just placed an order on a Dedicated Drag Setup for my 17 RS RWD. Dedicated Drag Setup will be:
For the Rears Only - 18x9.5 ET38 Silver Enkei RPF1 wrapped in 285/40/18 Nitto NT05R Drag Radials
They should be here by the end of the week. So, depending on whether or not it rains, I can probably hit the drag strip again either next Wednesday or the Wednesday after next.
Reactions: serstylz2
Just got my Dedicated Drag Setup test fitted in the Rears at America’s Tire... They fit! Car is lowered on RS-R Down Sus Lowering Springs with -1.9 degrees camber in the Rears.
91324
91325
Reactions: u1arunit
[email protected] Modelo virus in CA... Looks like the drag strip won’t be open until maybe April 8th.
2019 Q50 Luxe RWD
Modelo virus lol
You have a dragy? My 0-60 times have gotten much worse since adding the 275/40/19 Firehawks to my car. From 4.46 best/4.5--4.6 consistent, to 4.94--5.05 consistent.. not sure what I broke
No dragy here. If the drag strip doesn’t open up any time soon, I might put on my Dedicated Drag Setup, and then use my Ecutek Performance Analyser to log some runs.
91369
