in a PM or email? Haven't seen anything yet.@Ddnspider I sent you my file for analysis, appreciate any input
For sure.Any plans on redynoing after AMS finishes your tune?
Nice looking log. I haven't seen fuel trims exceed 100 before, but somehow the AFR is still looking good.@Ddnspider I sent you my file for analysis, appreciate any input
No prob.@Ddnspider I really appreciate you looking over the log and providing your input, I will definitely ask about the drop at 6k
What RPM did AMS set the launch control at? I believe that the tuner has to set it, but was wondering if we can change the RPM it is set at??My tune is coming along nicely. Latest iteration includes Launch Control. I have only tried it twice for logging purposes but when Brake boosting you can really hear the turbos spooling as they build boost. My fully applied brakes are having trouble holding the car. I’m a little concerned about breaking the stock drive shaft....
Seb set mine at 2600rpm but I haven't tested it yet. He sent me the update and said he had made some good changes but 2600rpm seemed a little higher than what I expected but I'll give it a shot.What RPM did AMS set the launch control at? I believe that the tuner has to set it, but was wondering if we can change the RPM it is set at??My tune is coming along nicely. Latest iteration includes Launch Control. I have only tried it twice for logging purposes but when Brake boosting you can really hear the turbos spooling as they build boost. My fully applied brakes are having trouble holding the car. I’m a little concerned about breaking the stock drive shaft....
John,What RPM did AMS set the launch control at? I believe that the tuner has to set it, but was wondering if we can change the RPM it is set at??My tune is coming along nicely. Latest iteration includes Launch Control. I have only tried it twice for logging purposes but when Brake boosting you can really hear the turbos spooling as they build boost. My fully applied brakes are having trouble holding the car. I’m a little concerned about breaking the stock drive shaft....
I wouldSSStart at 2200ish and work up if I could change the #. Seems foolish if we can't as the # set by the tuner could be to high or not enough depending on our particular car n mods.John,
Mine is set at 2250. I can’t imagine any higher.
I haven't tried it yet. Been lazy lately but I need to give it a shot.@QFittyRS I got my update from Seb, has it worked for you yet? I'm on the 3rd or 4th version and can't seem to get LC to engage.
Still insane to be running 23 PSI on 93 octane , that flex fuel can't come soon enough IMO. I'm sure you will see some strong gains though.Updated numbers before flex update and RT turbos. 23 PSI max on 93 pump.
444.78 AWHP
518.11 AWTQ
2017 Red Sport AWD
AMS Heat Exchanger
AMS Intakes
AMS Lower Downpipes
AMS Carbon Driveshaft
AMS Coolant Expansion and Auxiliary Tanks
AMS Ecutek Tune 23PSI max on 93
Z1 2-Piece Rotors
23 PSI on the stock turbos puts you completely off the turbo efficiency curve at less than 5000 rpm. You're just generating a lot of heat with no additional power at that boost level.Still insane to be running 23 PSI on 93 octane , that flex fuel can't come soon enough IMO. I'm sure you will see some strong gains though.
Yup, at 1.3 bar on 93 octane, my best dyno #'s were only -7 WHP and -15 WTQ from nr2134 #'s.23 PSI on the stock turbos puts you completely off the turbo efficiency curve at less than 5000 rpm. You're just generating a lot of heat with no additional power at that boost level.
You're running 4 PSI less boost than nr2134 and have essentially the same power output. That demonstrates the extra boost isn't helping much and is mainly stressing the turbos and engine.Yup, at 1.3 bar on 93 octane, my best dyno #'s were only -7 WHP and -15 WTQ from nr2134 #'s.
Unless both cars were tested on the same dyno, on the same day and in identical conditions, that is not a very good comparison at all. This is why I would take all dyno numbers with a grain of salt. One may, however, use dyno testing to see if modifications to a vehicle improved it's performance.You're running 4 PSI less boost than nr2134 and have essentially the same power output. That demonstrates the extra boost isn't helping much and is mainly stressing the turbos and engine.
I've given up trying to convince people of that. I think tuners like AMS are doing a long-term disservice to their customers unless the customer specifically says "I'm fine if my turbo's blow up later."23 PSI on the stock turbos puts you completely off the turbo efficiency curve at less than 5000 rpm. You're just generating a lot of heat with no additional power at that boost level.
