Please read the notes at the bottom for posting guideline.
FAQs go here:
1. Q: What is factory wheel size and offset on sport models?
A: Front is (RWD or AWD 19x9 +47 245/40/19) and the rear is (RWD 19x9.5 +50 265/35/19...AWD 19x9 +47 245/40/19)
2. Q: My rims are 19x9.5 +35 all around what's a good tire size to run with these specs? Also on BC coils and plan on slamming it any issues i'll run into?
A: 255/40/19 or 245/40/19. You may be able to get away with 265/35/19. The clearance limiter is going to be your rear fender at a +35.
Testing edit
Hyperlinks go here:
17"
18"
19"
20"
Recommended Camber settings for balance:
RWD
AWD
Q50 AWD with RSR coilovers and factory anti-sway bars
square 265/35/19 with a -2.2 Front camber should have between -1.8 and -2.0 camber in the Rear...NOT VERIFIED
(Note: A -1.1 front camber does not mean the rear would be between -0.9 and -1.0. You must figure out the proper balance independently)
square 275/35/19 with a -2.2 Front camber should have a -2.2 camber in the Rear...VERIFIED
(Note: A -1.1 front camber does not mean the rear would be -1.1. You must figure out the proper balance independently)
Posting Guideline:
To get the ball rolling. I will update this first post with hyperlinks to all useful posts.
This thread is not for random comments.
Please post the following:
While wheel make and model may not be very important, tire make and model may affect fitment as some tires run wider or narrower depending on manufacturer. You are more than welcome to post wheel make and model.
Feel free to add wheel and tire weights if you have that information handy.
Here is a useful example:
19x9.5 +40 265/35/19
wheels 20#
tires 27#
Please include pictures. This is very useful.
If you have a video, great...please add the link.
If you have a FAQ you want listed here, please post it with the answer...hopefully.
All comments/suggestions/answers are welcome.
FAQs go here:
Testing edit
Hyperlinks go here:
17"
18"
- Square 18x9.5 +40 255/45/18 RWD NON RS
- Square 18x9.5 +45 275/40/18 AWD NON RS
- Square 18x9.5 +40 275/40/18 RWD NON RS
- Square 18x9.5 +40 275/40/18 AWD NON RS BUT Enkei USA confirmed fitment for Akebono
- Staggered 18x9 +24 245/40/18, 18x10 +40 305/35/18 RWD RS
- Square 18x7.5 +45 235/50/18 AWD Sport on G37XS wheels
19"
- Square 19x9.5 +40 265/35/19 AWD RS
- Square 19x9.5 +40 275/35/19 AWD RS
- Staggered/Square 19x11 +45 285/30/19, 19x11 +45 305/30/19 RWD RS
- Square 19x9.5 +25 255/35/19 AWD RS
- Staggered 19x8.5 + 40 245/40/19, 19x9.5 +35 275/35/19 Non Sport
- Staggered 19x9.5 +19 235/35/19, 19x10.5 +22 255/35/19 RWD very aggressive camber
- Staggered 19x11 +40 275/35/19, 19x9.5 +25 245/40/19 RWD RS
- Staggered 19x10 +22 265/35/19, 19x9.5 +15 245/35/19 RWD Sport
- Square 19x9.5 +40 255/40/19 AWD RS
20"
- Staggered 20x9.5 +36 255/35/20, 20x10.5 +42 285/30/20 RWD RS
- Part 1 Staggered 20x9 +40 255/35/20, 20x10 +40 275/35/20 RWD RS
- Part 2 Staggered 20x9 +40 255/35/20, 20x10 +40 275/35/20 RWD RS
- Square 20x10 +40 275/30/20 AWD NON RS
- Staggered 20x8.5 245/35/20, 20x10.5 275/30/20 2014 Luxe
- Staggered 20x9 +35 245/35/20, 20x10.5 +45 285/30/20 RWD RS
- Square 20x10.5 +45 245/35/20 AWD RS
RWD
AWD
Posting Guideline:
- wheel diameter
- wheel width
- wheel offset
- wheel weight
- tire size
- camber settings
wheels 20#
tires 27#
