381 - 400 of 479 Posts
Discussion Starter #381
9.5 +50 275 = inside sidewall just touches inner suspension up front.
9.5 +45 275 = clears inner suspension by about 5mm.
10 +40 275 ~ should be about same clearance on inside to the suspension.
You will have to contact Titan to confirm that the particular wheel you want will clear the akebono brakes at an 18x10 +40. If so, you are good for the front.
The rear will poke just a bit FWIW.
So i’ve decided to go with 18x8.5+35 trying to decide whether to go 255/45 or 245/40, also wondering if i’d be able to get BC Racing or Tein Z coils on as well
Just ordered my wheels yesterday for my 15 Sport.
Ended up choosing Niche Misanos in Anthracite - 20x10.5 +30 squared and gonna pair them with 255/35s. Just need to do a bit of research on tires but I'm thinking either Michy Pilot A/S 3s or Indy 500s.
255 is way too thin for a 10.5 wheel
Discussion Starter #387
amazing how it looks just like a TL with those wheels!
You must not plan on doing any kind of digs/fast driving? 255 is narrow and 35 is not meaty at all. Those aren't going to hook at all... 245s stretch my 9.5" wheel right now, I'm going up to 275 in the rear for some traction
Hello all, I have a 2020 Luxe RWD 3.0T. I'm looking to purchase Niche Essen wheels in a 19x10 +40 squared set-up with a set of 275/40/19 tires. Im currently on stock suspension. Would I have any issues on the front with this set-up?
275/40 up front may be a reach...
Speaking of which, simpletire.com has a great deal going right now, I got 2 275/40/19 Firehawk Indy 500s for 378.xx, which includes shipping, tax AND installation. Prior to that, best price i was seeing was 380 for just the tires before tax/shipping
So if I want to clear akebonos brakes on my q50s, I want the konig oversteer 19x9.5 Would I need a +40 offset or +25 offset? Currently running 245/40/19 , might run 255
I believe there are some pics of this set-up on the Fitment Industries website. The face of that wheel in a +40 isn't super concave so it might clear. They could probably tell you if you called them. The +25 would prob clear but would probably poke out unless your dropped and running a little camber.
Forgestar CF5V Candy Red purchased from GetYourWheels
19x11 + 40 (Rear)
19x9.5 + 25 (Front)
Calipers painted by me in Duplicolor White
RsR Downs
Stock arms, stock camber
No rubbing
I'm looking at TE037s for my 2019 q50 red sport RWD
Fronts would be 19 x 9.5 +22, since you have +25, do you think that 3mm difference will make the fronts past the fender (I can't tell from your pic)? I'd rather have them flush or slightly tucked. My other option is 19 x 9 +34 which I am told is almost like stock...
Rears will be 19 x 10.5 +35 which I think would sit pretty flush or just slightly tucked.
Anyone have any insight on these specs?.
It all depends on your ride height. At the height that I am at, it will be flush with no issues.
Ah yeah I forgot to mention, I will be on RSR downs. That's great to know, my worry was that the fronts might sit out farther than the rears. Do you have photos of your wheels from a top down or front angle to see how they sit? If not, no worries.
91454
19x9.5 +25 squared; 255/40/19 tires & lowered on BC Coilovers
Reactions: Jsnc87
I wish there were Q50 gatherings near me. I think I'm the only one in Lincoln county, Oregon that owns a Q50.
This must be the reason why you have 6409 posts... ;)
