2015 Q50s Hybrid AWD: Z1 2 piece rotors, Stillen rear Sway-bar, Tanabe front strut bar
Hey Jo, I’ambfinally about to pull the trigger on either the Nismo wheels or the sport pac rays 19X 9. I noticed the Nismo wheels come with the same size tire from factory as the redsport. 245/40/19. Any disadvantage to running the oem size on such a wider wheel? Stretch? I think that size is at its limit at 9.5??
I would like a wider tire being at stock height, just afraid of rubbing but don’t Want to go down in diameter because I am a stock height, I don’t want the wheel gap to be too noticeable.
This is why I was considering the OEM Rey wheels at 9 inches wide because they are the closest to factory and I am on the 2015 sport wheels which are only 8.5 inches wide.
I also read initially that you had struggled with too much grip on the 275 tire and my vehicle is all wheel drive and I stock height I’m wondering if I will run into any similar issues.
Your feedback is greatly appreciated thank you so much
you can not have a 275 square fitment with +32. You will rub.
I am at 275 +40 and the rears barely...just barely clear at full compression at outside corner of tire.
