The front
The car is in the bodyshop currently, but I did a quick test in the front tires and the brakes did not clear spokes more than a 1mm.
Would you suggest selling the wheels versus putting a spacer on the fronts wheels?
Also the rears with +25 on 10.5 width from what you're saying will not clear the wheel well? How do I get the camber adjustsed/any negative side effects to doing so? (will i need an alignment?)
you can add 2mm spacers for more clearance. 5mm spacers will likely not push your tires out at 255 +35...ending up at 255 +30.
if you are asking about the rears and adjusting camber and do you need an alignment, it changes things a bit.
you will spend couple of hundred or more for adjustable control arms...add installation...add alignment.
you will need quite a bit of negative camber to tuck in the rear wheels. Enough that your rears will wear out fast.
I recommend you sell them.
go to page 1 and look at some fitments. then go through the pages and look at fitments...paying attention to widths, offsets and camber for front and rear.
please list your specific model and drive in your signature...for ex. 2017 q50 sport RWD.
if you can also add a list of your mods in the signature, it will be helpful for future reference.
what is your realistic budget on just wheels? what size do you want and why? how far do you plan to go in suspension mods?
decent wheels are a good 300 a piece.
