A 9.5" wide will be flush/near flush at a +35. Anything less will begin to poke. A +15 will poke from the body an inch and you will have to run a stretched tire to clear fenders. If you want hellaflush and are willing to run camber, I guess it could work.Hey guys I have a 2021 Q50 Luxe with the stock 18s and I was looking into getting the enkei RPF1 in 18x9.5 +15 I’m going for a super flush meaty look and was wandering if this offset is to aggressive or should I go with +38 instead
I’ve been going crazy trying to find examples but havnt been able to find any for the specs I wanna go for but I definitely don’t want them to poke out a lot I want more of a flush fitA 9.5" wide will be flush/near flush at a +35. Anything less will begin to poke. A +15 will poke from the body an inch and you will have to run a stretched tire to clear fenders. If you want hellaflush and are willing to run camber, I guess it could work.
The +38 is still aggressive, nearly flush, and you can run a 265/35. It will look super meaty because the tire will have a square sidewall. I vote for +38s.
After a ton of searching I found what I believe to be is a 18x9.5 +15. I think itlll look great paired with coil oversFitmentindustries.com or customwheeloffset.com has a bunch of q50s that you can search with different offsets.
I’m still debating on going with that offset but if I do I’ll most likely apply PPF on the doors and stuff as an attempt to minimize damage but I’m definitely expecting itThe lower portion of your doors and outer sills will get chipped up with that offset.
get the +38.I’m still debating on going with that offset but if I do I’ll most likely apply PPF on the doors and stuff as an attempt to minimize damage but I’m definitely expecting it
You think you can post a pic so I can see? it’ll help a looooootget the +38.
NOT the +15.
You have been warned.
You may still run a 275 tire on that +38 IF you give it about -2 camber...which is what I run all aound on my AWD because I need it for handling.
can you go to the first post and click all those fitment links?You think you can post a pic so I can see? it’ll help a loooooot
Thanks! Also trying to decide between brushed/satin silver or matte graphite for the color. What do people think looks best (my car is hagane blue)as long as those wheels clear your front brakes, that setup is fine.
I've always been a fan of wheels contrasting the car, i.e. light on dark and dark on light.Thanks! Also trying to decide between brushed/satin silver or matte graphite for the color. What do people think looks best (my car is hagane blue)
you need to ask the manufacturer if the 9.5 +45 clears the brakes.Please correct me if I'm wrong. I'm planning on getting the wheels in the link below except 9.5" wide (instead if 8.5) and 45mm offset (instead of 38). They obviously clear the front calipers in these photos. My assumption is that the spokes on the wider wheel will be 5.5mm further from the hub mounting surface of the wheel and should therefore not have any problem clearing the sport calipers, provided no spacers were used in photos I've linked to.Infiniti Q50 White Asanti ABL-12
I guess it just depends on the wheel. Muskie28 is running 19x8.5 +45 (12.5mm less room for the caliper than the x9.5) it would seem with no problem.Post A Picture Of Your Q50you need to ask the manufacturer if the 9.5 +45 clears the brakes.
IMHO, they wont. most aftermarket wheels are good at +38 or +35...especially at 9.5".
i dont know of any aftermarket 9.5 +45 that would clear.
Those are clearly high-quality wheels designed to be light weight, so I can definitely see how the spokes starting to curve inward toward the mounting surface so close to the barrel could cause some brake clearance issues with a high positive offset.19x9.5 Rota KB-R +37.5mm (40mm offset + 2.5mm spacers)
Wheels cleared Akebono big brakes by ~1mm, but added 2.5mm spacers for a little more room
285/35R19
