normally after gear in park, is preferred way as some times car does adjust the gear and there is gear pressure in the transmission. Putting in part the gear pressure is not there on your E b or parking brake
but its a good practice to use parking brakeI don't apply the parking brake. Houston is flat.
Ditto!I've noticed a little lurch with the gearshift to park then applying the parking brake method. I go to neutral first then apply the brake, release the foot brake then shift to park. My .02 for what it's worth.
Same here. Especially on inclined surfaces when I park I do the same. Takes the pressure off the transmission when shifting to drive when you're ready to drive again.I've noticed a little lurch with the gearshift to park then applying the parking brake method. I go to neutral first then apply the brake, release the foot brake then shift to park. My .02 for what it's worth.
This is what I've always heard, so I always put on the parking brake while still in Drive and then I shift to Park.To me, it's pretty obvious that you'd want the BRAKES holding the car, with the transmission as a back up, rather than the other way around.
