I DONT KNOW WHAT UR TALKING ABOUTMake sure you get brake fluid instead of break fluid.
All brake fluids are technically synthetic. DOT3, DOT4. and DOT 5.1 are glycol-based and acceptable but DOT 5 is silicone-based and not compatible with the Q50 braking system.If your hard on your car change to Synthetic brake fluid. DO NOT use SILICONE Dot 5 brake fluid. Use the propper bleeding sequence when flushing the brake system. I would recommend OEM transmission fluid. For the rear diff service use the appropriate weight Synthetic gear oil in either Amsoil or Royal Purple. Don't forget the friction modifier additive if needed.
Sounds like something I might do.Make sure you get brake fluid instead of break fluid.
Now that you mention it...Sounds like something I might do.![]()
