Found this interesting...so basically, unless you used the Personal Mode in your test drive, you did not actually customize the steering...because your personal steering settings in the inTouch system are only used when you are in PERSONAL driving mode.
PERSONAL MODE
When the PERSONAL mode is selected, the
following functions can be adjusted individually.
. Engine·Transmission
. Steering
. Active Trace Control
How to set the PERSONAL mode
Perform the following steps to set the
PERSONAL mode.
1. Push the MENU button *1 and touch
[Infiniti Drive Mode Selector] on the
lower display.
2. Touch [Engine·Transmission], [Steering]
or [Active Trace Control] and select each
item. (See “Engine·Transmission”,
“Steering” and “Active Trace Control”
about the feature of each item.)
3. Touch [Back] or [Home] to finish the
PERSONAL mode setting.
Engine·Transmission:
“Engine·Transmission” can be set to
[Sport], [Eco], [Standard] or [Snow].
Steering:
Four combinations of steering effort and
steering response can be set.
Steering effort Steering response
Standard Standard
Standard Quick
Heavy Quick
Light Casual
PERSONAL MODE
. Steering
PERSONAL mode.
lower display.
Steering:
Standard Standard
Standard Quick
Heavy Quick
Light Casual
