Already 5 TSBs at http://www.infiniti-techinfo.com/TSB/TSB_xml/nmIndex.aspx:
Subject: SB Infiniti; On-Car Brake Rotor Resurfacing
Summary of ITB04038:
If YOU CONFIRM: A vehicle needs to have the brake rotors resurfaced (front or rear). ACTION: Use the ProCut PFM Series on-car brake lathe to perform brake rotor resurfacing and follow the tips listed in this bulletin. - The ProCut PFM Series brake lathe has been chosen as the approved tool for rotor resurfacing. - The ProCut PFM Series brake lathe can be ordered from TECH-MATE at 1-800-662-2001. - ProCut technical support or service can be obtained by calling 1-800-543-6618. NOTE: Brake rotors may need to be resurfaced during routine brake repair or for brake "judder" incidents. - Brake judder: A brake pedal pulsation and/or steering wheel shimmy when braking that occurs when there is too much thickness variation of the brake rotors(see ITB00-024). See this bulletin for further detail.
<LI style="TEXT-ALIGN: left; MARGIN-LEFT: -30px; MARGIN-RIGHT: 30px">
Subject: SB Infiniti; Paint Refinish for Scratch Shield
Summary of ITB07047: SERVICE INFORMATION Scratch Shield is a scratch-resistant clear coat which "heals" by itself when the vehicle gets a small scratch in the clear coat. If the scratch reaches the color base coat, however, it will not "heal". Scratch Shield was implemented for the first time in the U.S. with the 2008 EX35. NOTE: Scratch Shield is applied to body panels and fasicas only. All vehicles that have scratch shield clear coat carry a label which is typically located underneath the hood. See this bulletin for further detail.
Subject: SB 2014 Q50; Display Control Unit (Upper Display) Replacement
Summary of ITB13026: SERVICE INFORMATION If the Display Control Unit (DCU) needs to be replaced on an Applied Vehicle for any reason, follow the steps in the Service Procedure to: - Confirm proper diagnosis and repair with TECH LINE to obtain DCU order approval. - Configure the Multi AV system. - Register the replacement DCU. DCU registration is necessary whether or not the vehicle has an active Infiniti InTouch Apps subscription. NOTE: The original DCU must be installed in the vehicle while performing part of this procedure. DO NOT remove the original DCU until instructed. See this bulletin for more detail.
Subject: SB Infiniti; Recommendation against Making Changes to Front Seat Trim Materi
Summary of ITB00031: SERVICE INFORMATION Changes or modifications to the front seat assembly trim materials may affect the proper operation of the Front Seat-Mounted Side-Impact Supplemental Air Bags and Passenger Occupant Classification Sensor and could result in serious personal injury or death. Infiniti STRONGLY RECOMMENDS AGAINST making any change to seat trim materials from the factory equipped condition. This specifically applies to replacing the seat trim with non-factory materials; adding leather/cloth seat covers, seat pads, or seat storage pouches, etc. around or over the seat back and the passenger seat cushion. See this bulletin for further detail.
Subject: SB 2014 Q50; Steering Pull and Steering Wheel Off-center at PDI
Summary of ITB13029: SERVICE INFORMATION: During the Pre-Delivery Inspection (PDI) test drive, you may experience the following conditions: - While driving straight the steering wheel is off-center, and - While driving straight, if you relax your grip on the steering wheel, the steering wheel will return to center and the vehicle will pull, as if making a turn. The above condition indicates that the Direct Adaptive Steering (DAST) needs to be trained (recalibrated). NOTE: Do not perform a wheel alignment for a steering wheel off-center or pull condition at PDI. See this bulletin for further detail.
