Does anyone know much life I will get out of the front brake pads? I currently have 67,000km on the original front pads and they dont seem to be wearing out quickly at all. Rears are another story, had to change those at 44,000km.
Pad life varies a lot depending on driving conditions and driving habits. I do expect my front pads to go over 50k miles easily while the rear pads might not even reach 45k miles.
You should be able to see the pads from the access panel at the top of the calipers, you may need to turn your wheel to get a better look at it however.
Not a perfect measurement by any means but it will give you a good idea.
Besides your wear indicators will start squeaking on you once they get really low.
My brakes squeal often at parking speeds, but are very easy to see. I can not speak to the OEM pad life. I have ATC OFF in personal mode to keep the rear pads from being used unnecessarily.
Theres an access panel at the top of the calipers? I never knew there was one there...im usually trying to look through the side opening but its very difficult to tell whats what.
I have seen it used many times on several different manufacturers vehicles without removing the wheel but removing the wheel does make it a bit easier.
So I been driving my Q around alongside with my old Accord.
I'm starting to notice that every time I step on the gas, I'm getting a .5 or a 1 second delay for me to get a "response" and that burst of acceleration hits me at all at once. It feels like there's not a gradual acceleration.
I've...
I recently hit 30K miles with my 2015 Q50 Premium AWD and am looking into changing out the fluids. I would never pay anyone $200+ to unscrew a bolt, drain, and fill. I honestly do not know how a dealership can rationalize charging those kinds of prices for fluid changes (it doesn't take anymore...
Hey Guys!
I just wanted to kick this thread off and let you know that the development for our Q50/Q60 air-to-water heat exchanger is underway!
With the RS400 in our shop for final catch can testing back in March, we evaluated the VR30DDTT's intercooling system and decided to add our own...
so, long story short...i pulled my 2014 q50 out of the garage to pull my other car in. i left the q50 running so i could pull it back in the driveway and forgot...6.5hrs later (at about 2am) i realize that i forgot to pull the car in...the heater was at 90 degrees, both seat heaters and...
Hellos Friends,
Been poking around the internet on tuning kit for my 2015 Q50s hybrid. Found nothing, so figured I post it here to see if anyone know. I already and exhaust and cold air intake.
Thanks in advance.
Cheers,
sithbk
A forum community dedicated to all Infiniti Q50 owners and enthusiasts. Come join the discussion about modifications, troubleshooting, hybrids, maintenance, reliability, and more!
