Peak torque is like 3500-4500rpm depending on tune.I can already deadhook 1st. And you don't want a torque converter above peak torque. These motors have such low peak torque. I've stalled mine to about 2k, but can't leave in boost....not 1-2 psi. I mean real boost. That would likely drop at least .25 off the 60ft.
Isn’t our stall around 2400? A 3400 stall would do wonders.
When you say stalled to 2k but can’t leave in boost what do you mean? Wheel spin and can’t hook? Or Hooks and then bogs? Or it doesn’t build any boost? can you flash stall with the brake, hold brake floor it lift brake right as it hits 2k might build more boost off the line.
