I've got skin tags older than you....kids....heh.That's right he is old and crafty
Avedis53... Alcohol is anhydrous and absorbs water. That's why it's banned in aviation fuel. It reeks havoc in my small engines. Soooo I want a source of volume gasoline w/o etoh in it. The airport is close by and pumps fuel. But it's over 100 octane. It's also fairly expensive...I know just enough to be dangerous...so look out.
If those small engine devices are 2 stroke do what I do. I have a Stihl blower and string trimmer. I use their "Moto Mix". It is a 99% alkylate fuel with a synthetic oil added at 50:1. It is 93 octane and has a shelf life of years. It eliminates the hassle of mixing and performs great. It is expensive at $7.00 per quart but those small engines consume so little it is worth it. Two quarts will last me all season with fuel left over. At the end of the season I just clean the tools up and put them away with whatever is left in the tank. They start on the first pull next spring. No hassles. No need to add Sta-Bil. Clean burning also. May extend the engine life of your devices.Avedis53... Alcohol is anhydrous and absorbs water. That's why it's banned in aviation fuel. It reeks havoc in my small engines. Soooo I want a source of volume gasoline w/o etoh in it. The airport is close by and pumps fuel. But it's over 100 octane. It's also fairly expensive...
?? Will this hurt a lawnmower, leaf blower, lawn tractor chain saw, or outboard motor? I thought high octane just prevented detonation, a flame retardant of sorts. To much octane is a waste, but is it harmful?
The closest non alcohol place that pumps gas at under 100 octane (90 i think) is 2 hrs away. 4 five gallon tanks might be worth the trip. I also heard VT is considering banning gas that has alcohol in it since it's hurting the tourism industry (boating). If so I can't wait!
If I recall correctly, the high altitude in most of Colorado makes 93 octane unnecessary.Hey all - currently live in Denver, CO and can't find 93 anywhere in the state! I'm using all the websites available, reddit, etc. just nada! C'MON COLORADO! Anyone know any places? Thanks so much!
Yes. For example, instead of 87 octane regular unleaded, in CO they sell 85 octane regular unleaded.If I recall correctly, the high altitude in most of Colorado makes 93 octane unnecessary.
That's a great question! I agree with your logic for sure.Wouldn't you just offset less dense air with more boost and need the higher octane at that point? Obviously there is a limit, but at mid RPM say someone at sea level runs 16PSI boost, couldn't that be offset by running 18PSI (or whatever the math is) in a high altitude area?
Love it, thanks so much for the response and the graph. Cheers!View attachment 100606
Going from sea level @ 21% O2 up to Denver, CO @ 5280 feet drops the O2 down to about 11%. So about half the oxygen is available. More boost would be required to achieve the same amount of oxygen charge to the engine.
BorgWarner says a good rule of thumb is that the turbocharger impeller speed will increase 1%-2% for every 1000 feet of elevation gain.Just be careful how fast your spinning the turbos! If you have a red-sport, the car will monitor spin speed for you. If not, you may run into an issue! Not sure the relationship of spin speed to PSI when air is 20% thinner. Seems these turbos have a max PSI around 20 or so at sea level, so they may not be capable of producing 18 PSI in Denver? MIND BOGGLING!!! Would be interesting to see all the math on it!
Thanks JCB, IJust be careful how fast your spinning the turbos! If you have a red-sport, the car will monitor spin speed for you. If not, you may run into an issue! Not sure the relationship of spin speed to PSI when air is 20% thinner. Seems these turbos have a max PSI around 20 or so at sea level, so they may not be capable of producing 18 PSI in Denver? MIND BOGGLING!!! Would be interesting to see all the math on it!
Thanks for the response, I totally agree. Finally getting the Q on a dyno in the upcoming weeks - crazy back log of customers waiting as well. I guess the pandemic created a lot of new gear heads! I'll share my results from my appointment and JB4 logs.Just be careful how fast your spinning the turbos! If you have a red-sport, the car will monitor spin speed for you. If not, you may run into an issue! Not sure the relationship of spin speed to PSI when air is 20% thinner. Seems these turbos have a max PSI around 20 or so at sea level, so they may not be capable of producing 18 PSI in Denver? MIND BOGGLING!!! Would be interesting to see all the math on it!
