Not sure if this only applies to models with around view camera only but when backing up, there is the option to display the rear camera in wide mode vs the split standard rear view with the around view monitor.
The negative on the wide rear view is that the guide lines are no longer trajectory.
I do find the standard rear view mode (split with the around view monitor) is not quite wide enough but does add the benefit of trajectory lines.
I've played with setting the default to wide rear view only or split screen and sometimes do prefer the wide view.
