So my Q50S arrived at the dealership yesterday. Went to take a look and it looks great (even with plastic wrap/protection all over it). Couldn't test drive it, but they did let me get in and start it up. I noticed the touchscreen took a while to load and the lag was still there. Dealer said the update was planned for Aug 3-4th (take that with a grain of salt because he hasn't exactly been a wealth of knowledge of when the car was to arrive or anything else aside from being able to process my credit card deposit in a matter of minutes).
My question is this: The touchscreen and dependent systems are essentially tied to a computer with an Intel processor. Every computer I've ever owned/used has had a pretty finite life (2-3 years). After that time, it starts to load slower and slower until it's eventually unusable. You can do software updates all day long, but swapping out the hardware is going to be a major deal. So how does Infiniti plan to ensure this computer lasts the life of the car and continue to function as intended?
Proactive counterpoint to myself: Most car systems (even the one's in the current G line up) are powered by some sort of system and do just fine switching between audio, navigation, etc and the fail rate is pretty low and little lag is noticed over the life of the car.
Proactive counterpoint to my counterpoint: The Intouch system seems different than most current systems, with a much higher degree of "customizability" and less of a defined functionality that doesn't change. It's designed to "mimic" smartphone capability/functionality which has, arguably, a more limited life than a laptop. The ability to add new apps is great, but it usually means ever increasing RAM requirements (or whatever the equivalent is in smartphones).
To summarize this debate with myself, how do I feel confident that this heavily technologically reliant car is going remain capable of doing everything it does from day 1, as good on day 2,000?
