Replaced 2 Dunlop Run Flats within 2 weeks
I have a 2014 Q50 AWD Prem that has 19" Sport Tire & Wheel AWD PKG. These are the Dunlop 245/40R/19 All Season run flats.
While driving I hit a small pothole on RT Front and when I got to my destination, noticed a small slit in the sidewall. Drove on it for 1 day and then warning light went on that low PSI and then tire went down to 0. Next day called dealer and to my surprise, I was informed it was $425 to replace. Dealer said nothing can be done as I hit a pot hole. I said that was BS and then paid my invoice that included time and labor.
1 Week later while driving back from Louisvile to Michigan, half way home just outside Indianapolis, Warning light comes on and now my LT Front low pressure and then down to 0 - FLAT. Take to dealer next day and get manager and owner of dealership. They take off and inspect tire and say this looks to be caused by pothole and the rim is damaged a little which looks to be caused by hitting a pothole.
2 Tires, almost $1,000 and the dealership says nothing can be done as both look to be damaged by me hitting potholes. This is crazy and this is an expensive car and these tires to me are Junk that cost $400 each. Dealer also told me luck the rim was not damaged as to replace they are almost $1,200 each.
Infiniti and or Dunlop need to step up and help owners out. This is not a cheap car and we should have better tire options and or warranties. I have never had a flat tire ever with any of my other new cars and or new used cars. These tires cost more than the 22's on my ESV Escalade.
Based on these Dunlop tire reviews, life expectancy is 20-22K miles which then leaves me paying almost $1,600 + for new tires. Dealer tells me there is no other tire options for this size wheel. This leaves me with a very bad taste with both dealership, Infiniti and Dunlop.
Pissed here in Michigan
