Put the car in reverse and the mirrors don't tilt down. This worked previously. Any ideas what is going on?
Make sure that the mirror selection switch is not in the middle. move it to the driver or passenger side and see if that corrects the problemPut the car in reverse and the mirrors don't tilt down. This worked previously. Any ideas what is going on?
The next time it sticks, use your hand to push the glass into place. Sometimes when washing or drying the mirror you might push the mirror down and it has to be reset. Worth a try.Well, mine still tilt down but my driver side mirror has stopped going back to its regular location when I shift out of reverse about half the time. It ends up somewhere in the middle. I have to put the car in park and hit memory 1 for it to return to the proper setting.
Just the lasted item on my long list of things, big and small, that don't work properly on this car. This problem just started for me this week.
I would tell Infiniti Client Relations about it....if they would return calls.
This is the answer to the OP's question. It is a feature, not a bug.Make sure that the mirror selection switch is not in the middle. move it to the driver or passenger side and see if that corrects the problem
That was the problem. Thanks!Make sure that the mirror selection switch is not in the middle. move it to the driver or passenger side and see if that corrects the problem
Its part of the Deluxe Touring Package.Is this feature on all Q50? I don't recall mine having this feature. I have a '14 Premium AWD.
I believe you need to select the mirror that you want to tilt. If the switch is in the middle neither will tilt.Same problem here one side tilt down work and other one won't.
Yup that fix mine! Thank you!Make sure that the mirror selection switch is not in the middle. move it to the driver or passenger side and see if that corrects the problem
Hate to dig up an old thread but thanks! I thought that feature stopped working out of the blue.Make sure that the mirror selection switch is not in the middle. move it to the driver or passenger side and see if that corrects the problem
I've downloaded both the Owner's Manual and InTouch Manual so I don't have dig out the manuals from the car if I'm looking for information.
