1 - 5 of 5 Posts
I have heard that you can use a donut off of an Nissan Altima? Anyone done this or see why it wont work? Tired of Runflats no pun intended.
No idea but the one off a G37/370Z is the exact one you need. Search the forums, theres all the info you need about it
I have a space saver tyre that I only bring along on long trips. The problem with the space saver tyre is that the tyre can only be mounted on the rear, as the space saver tyre does not clear sports brake on the front.
So if you have a flat tyre on the front, you need to take off the rear tyre first, mounted to the front and mount the space saver tyre to the rear.
The Infiniti/Nissan space saver spare size T145/70R18 clears the sport brakes in both the front and rear. It is designed for that purpose.
Where did you see a problem with the front?
1 - 5 of 5 Posts
