1 - 20 of 92 Posts
So, I noticed that the Sport comes with a significantly larger brake system than the Premium (Sport - Front 14in, Rear 13.8in vs. Premium - Front 12.6in, Rear 12.1in). What all would it take to upgrade the system to genuine Infiniti Q50 Sport brakes? Is it simply just the rotors or does the whole system need to be replaced? Does the ECU have to be reprogrammed if the swap is done?
I'm not familiar (or mechanically savvy) with brake systems and certainly not read up enough on Infiniti since I've only been in the club a week and a half! Just thought I'd ask the question...if it hasn't been asked already somewhere.
I did the bbk conversion on my premium. What you need:
-Akebono calipers with hardware if not included already (this can be used from any year/model infiniti with the sport brakes)
-Pads with hardware
-Rotors
-Shorter Banjo Bolts
-Uses oem lines, or you can get stainless steel lines (much better pedal feel)
This is assuming you don't buy a full kit will all the necessary items
Got it...thanks!
-Pads with hardware
-Rotors
Reactions: a-Sarkar
This is my next upgrade too. Sorry to sound dumb, but what exactly falls under 'hardware' when speaking of sport brakes? Part numbers would be great..
Shim kit, but some pads come with them already. If not, part numbers below.
Carlson front hardware (13619)
Carlson rear hardware (13620)
Centric front caliper kits (143-42038)
Centric rear caliper kits (143-42039)
I have heard these brakes can cause premature warping. Have you had any issues with this? I know there are a thread or two about these already.
I noticed it's more so on factory pad/rotors, I went with stoptech pads and rotors, no issues
Reactions: Nemesys
i'm actually going with aftermarket pads for this reason. just trying to figure out if the pad shape is the same between a sport package from 2014-2015 and the red sport 2017. all sites claim they don't make any pads yet, but i'm guessing the pad shape is the same and its just not updated yet
No guessing needed. They're the same pads. They're the same Akebono calipers. Just some are now red instead of silver.
FYI, just because I was second guessing myself, the brake pads for the red sport's are the same as all previous sport models that have the Akebono calipers, whether silver or red.
The part numbers for purposes of purchasing OEM pads OR to crossover to aftermarket application are:
D1060-JL00J, front pad set
D4060-JL00J, rear pad set
Any one here with the Akebono calipers close to needing brake pads? If so, please send a PM to me. I just need one person and this is NO COST to them. I need some feedback on something and those details will be shared in the PM.
*EDIT* Found my tester.
Silver Akebono's
41001-JL02A, right, front
41011-JL02A, left, front
44001-JL02A, right, rear
44011-JL02A, left, rear
Red Akebono's
41001-5CA0B, right, front
41011-5CA0B, left, front
44001-5CA0B, right, rear
44011-5CA0B, left, rear
-Pads with hardware
-Rotors
Did you end up using the OEM lines? I'm really considering upgrading to the Akebono BBK for the nicer looks (and slightly for the better stopping power lol), but was wondering whether I needed the SS brake lines.
I ended up getting SS lines since it was going to be off anyways (well worth imo, big increase in pedal feel) but the regular lines can be used
I've also heard about this problem with Infiniti Sport rotors warping . I can't help but wonder why Infiniti hasn't upgraded the quality of their rotors by now instead of paying all the labor they're putting out to resurface so many rotor problems. Maybe it's cheaper to just repair a problem rather then correct it.
Might be checkin these guys out I just sent an email to them and they said they rebuilt the internals of the calipers and the painted them, but they also saw non painted ones too if you wanna DIY
Same part number:
Silver Akebono's
Red Akebono's
Pretty good deal:
Akebono Infiniti Calipers G37 M37 Q50 Q60 FX QX Nissan 370Z Maxima Front Rear - RC Tuning
Akebono Infiniti Calipers G37 M37 Q50 Q60 FX QX Nissan 370Z Maxima Front Rear Raw Finish - RC Tuning
1 - 20 of 92 Posts
