1 - 4 of 4 Posts
Q50S 2015
I designed a new look using start button rings (audi in this case) and a washer in which I grinded to make my new face.
The oem outer ring needs to be cut free from the retainer with an exacto and patience. You'll also have to grind the collar, underneath is inductive coils. I found it easier to remove it and rewire it - pita.
So the entire ting can be sandwiched together
92261
92263
92264
I changed the leds to red and did the manual indicator on the shift panel to red as well. IT's all smd LED and easy to do if you know how to solder smd
92262
I happen to really like the OEM button and its gunmetal ring but I commend you for your innovation.
So that outermost gloss black ring is a painted washer?
Reactions: socalsupra
Q50S 2015
That's right, just drilled to the right size. I got the chrome factory ring and not liking it too much
So you are changing your dash lights to red too?
Unfortunately, it looks like there is some marking left over around your new start button bezel because the original start button bezel was bigger?
1 - 4 of 4 Posts
