1 - 7 of 7 Posts
Finally got my garage finished and the first project was the spring install . The 3rd set sold and first installed
More pics and full review to follow
Nice nice! Any close up on wheel gap! Maybe get some finger action in there? :D
How is the ride quality of your BC coilovers ??
They are quite nice actually! Went a little stiffer after I saw that my fender was getting pulled because of the beefier tires and soft settings! Now that I have stretched my tires a bit and ran true sized tires, I have more clearance and I just might soften up the dampening! Right now @ 10 from soft in front and 5 from soft in the rear! It was basically like Oem when I had mine set @ 2 from soft in the rear and 5 from soft up front!
Hope that helps! :)
Ten k yes just a touch it feels more like a 370z no bounce or float barely any stiffer .i feel if you remove the run flats at the same time you would never tell a difference
1 - 7 of 7 Posts
