1 - 12 of 12 Posts
2014 Infiniti Q50 2.0t
Guys, every time I pull into, let’s say like in a gas station, the brakes apply themselves and the traction light flashes then goes away. Only happens when the wheels are turned either left or right. Any advice?
rear left tire is worn; TPMS is missing from right front wheel. Could that be the issue
Trac doesn't use TPMS to my knowledge. Are you AWD? If not it just sounds like a bad tire.
I had a similar problem with my qx70. took it to the dealer and they topped off the brake fluid. It happened (3) QX70s that I owned. Not sure if that helps but I would check the brake fluid.
Where did the brake fluid go? Did they offer an explanation?
1 - 12 of 12 Posts
