21 - 27 of 27 Posts
2018 Signature.
slight glitch yesterday.
the transmission felt like it slipped from a stand still.
it did this two separate times.
try as I might, I have not been able to replicate it from a stand still or while moving...partial or full throttle or manual mode.
So do you think that the new fluids settle in, keep an eye on it, after I had my tranny fluid changed I've not noticed any slipping.
Reactions: jodedor
Allen, Texas
Fingers crossed it was just solar flare activity and not a slipping clutch pack. Did the slippage occur in just 1st gear?
yes...just first gear...not even a dig just normal acceleration.
sar flares...who knew. thanks for the reassurance.
Allen, Texas
Don't forget the Full Moon effect...
Reactions: jodedor
alright...so I took it in this morning.
it was 1/2 qt low.
tech said maybe the fluid want hot enough when he checked it last Friday.
Anyhoo...shifts better and not as jerky from what I can tell.
Havent had slippage. will update if I do.
Reactions: rpiotro
St. Louis, MO
1/2 quart is a fine line to cause slippage. Any chance it was more than that and they don't want to admit it?
I wouldnt know.
But the advisor and master tech appear to be straight shooters.
Remember, the slipping was from a stop. didnt happen at speed. You'd thing it would tend to slip in taller gears similar o a manual transmission as the clutch starts to go.
21 - 27 of 27 Posts
