1 - 5 of 5 Posts
Hey Guys,
My Q50 is being delivered tomorrow with the standard wheels. It's a 24 month lease and I heard how horrible the stock RFT's are. My question is how many miles with normal driving should I expect to get out of them. The reason I ask if it's around 20K miles I'll go ahead and replace my tires now with non RFT and enjoy it then return the car with the original tires. However if the will last something like 50K miles then it would be a waste to put money on tires when these will last me through my lease. I also assume the car has to be returned with run flats is that correct? Thanks!
Hey Guys,
Not sure anyone has a good answer as no q50 owner has enough miles yet. However 50k miles on run flats is impractical. Based on g35/37 experience, you might get between 20k and 25k. But this is only a guess. Best to check some other forums.
You might want to check this out: Car owners tire of run-flat tires
Hey Guys,
21K AWD 17 stock
POTENZA RE97AS RFT
between 7/32 and 8/32 thread left (new thread depth 10/32")
If you keep tires properly inflated (35 cold) and rotated each 5k or 6 months (whichever driving style fits better) - you will be fine by end of lease. Especially if you lease another Infiniti since you will get $500 tear waiver credit.
And you are correct - RFT equipped cars MUST be returned with RFT tires and do not listen to anyone saying otherwise - you will be taking huge chances attempting to return non RFT and not get hit with surcharges. (some people get lucky once in the blue moon though)
Also keep in mind that tread wearing FASTER on NEW tires - the less thread left the SLOWER it will wear.
P.S. And I drive like maniac - so I am really surprised to hear stories from people that they need new tires or brakes after 15K LOL
Just turned 12K miles. Have the stock 17" Potenzas. Have 7/32" tread remaining. At that rate I am guessing about 25-30K miles till I'm on the wear bars. I would describe my driving style as spirited, not a maniac. Generally fairly easy on the brakes.
I have never rotated the tires. The wear is amazingly even front to rear and across the tread. I think I will stick with that program. At least until I find a garage that knows how to properly torque the wheel nuts.:crying: Of course YMMV.
1 - 5 of 5 Posts
