http://www.infinitiq50.org/forum/problems-solutions/12410-steering-lockup-caution.html
There are a few posts out there (see above) of people getting concerned about sudden loss of Direct Adaptive Steering. So – I wanted to see what it really feels like.
Cautions: When you do this test you will not be able to re-start the car until you come to a complete stop and can press the brake pedal again to start. Note that with the engine off you still get pretty good brake response. And as I describe below, steering is not too difficult. You can do this test in any drive mode. You can do this test in neutral and in drive. If in drive, you may notice some shaking due to the backpressure in engine (engine off, but cylinders still moving). I recco doing it both in drive and neutral so you can simulate loss of all power and just loss of DAS.
First: find an empty parking lot. Roll your windows down so you can get a good sense of the sound of the steering clutch engaging.
Second: Drive about 10 mph (and push gear lever to neutral). Next, HOLD DOWN the start button. In about 3 seconds the engine will cut out and the steering wheel clutch will engage. You’ll hear it and may feel it in the steering wheel.
Third: Practice steering left and right. You will find it’s quite do-able. As you turn the wheel farther and farther you will feel a variation in steering effort needed to turn. But at no time is it overly challenging.
Fourth: Brake to a stop. Put gear lever in Park. Push brake and push start. You may hear the mechanical steering clutch release. Normal.
If you want, try at higher speeds or in a turn as conditions allow.
In my opinion, the Q50 with failed DAS is much easier to steer than some of my previous power steering cars with engine off (All my previous cars were manual and at one point or another I’ve had to push start a dead car = no power steering or brakes). It’s also MUCH easier to brake as I get numerous pushes of the brake pedal before the braking effort gets difficult.
In conclusion, I feel the Q50 is properly engineered for this failure mode and allows any driver to safely control the car should DAS fail.
