1 - 13 of 13 Posts
I much prefer the "Wide View" camera setting when moving gear shift into reverse. Have tried "Settings, Camera/Sonar, Camera, Camera View Priority. 3rd Screen, Wide" , but it will not save the "Wide view". Seems like it should be a save-able setting...how can I save it so that it shows the wide view whenever I move the gear shifter into reverse??
Thanks for any help.
Bob
2016 Hybrid 3.5 SportTech RWD
Try the "Camera" switch beside the shifter. You should be able to click through different view options while screen is in work...
Automotive design Camera lens Grey Gadget Personal luxury car
That switch only changes the view for that particular venture through reverse (or at most the current key cycle). It reverts back to the standard default view the next time.
2021 Q50 RedSport, MBRP Cat-Back. HKS BOV, AMS LDP, Mishimoto Catch Can
I have seen Q50s in the past that would open AVM and it would be on one of the other view options as default. I'm sure it's possible but unfortunately do not know how to, Avedis will however
I agree....thanks.
I'll check that, not sure if that's the same in my car...
I'll check wether it'll revert to default (IIRC back camera left half and 360° right half of upper screen) every time I put it in reverse – I'm not sure if my car does that or keep the last setting...
EDIT: I remembered wrong – the camera view actually changes back to default every time I put it in "R"...
Reactions: Pillboy
Discussion Starter · #10 ·
Mine too....thanks anyway.
Reactions: DeeCee
I figured that was going to be the outcome, but I thought that maybe being a Euro-spec car, there was a chance it could be different.
Reactions: DeeCee
...maybe being a Euro-spec car, there was a chance it could be different.
Exactly what I was thinking, but this time...
Discussion Starter · #13 ·
Thanks for everyone's interest...
1 - 13 of 13 Posts
