1 - 5 of 5 Posts
Vendor
The AMS Performance Red Alpha Cold Air Intake System for the INFINITI Q50 or Q60 is simply the best engineered, best performing, cold air intake system available for the VR30 engine. By letting the turbos ingest all the cold air they need, our intake system boosts power exactly where you want it, high in the rpm range. In addition, it allows you to hear your twin turbos spool up which is something you as an enthusiast can really appreciate. AMS Performance is excited to introduce the INFINITI Q50 and Q60 VR30 Red Alpha Cold Air Intake System!
The main components of the Red Alpha Intake System are the sealed cold air intake boxes. Our SnailWorks© Engineering Team knows that heat is the biggest power robbing factor that plagues other inferior intake systems. That is why they designed the Red Alpha air boxes to seal out blistering engine bay temperatures. They then took advantage of your car’s existing intake cowl that funnels fresh air into the intake boxes by designing air box openings that match up perfectly to its air ducts. Our Engineers did not stop there. When they focused on the other system components they found even more places to improve the design.
The Red Alpha Intake System’s dry media air filters feature a revolutionary integrated bell horn. The AMS Engineering Team designed a bell horn right into the design of the filter. This takes the clean, cold air, that is fed into the system through the dry media filters and smoothly transitions it into the stock MAF housings. This design feature eliminates the turbulence that leads to the power loss, instability, and “bucking” of other intake systems. The last piece to focus on was the silicone that feeds the cold air into the two Garrett turbos.
Benefits:
  • True Cold Air Intake
  • Sealed Intake Boxes
  • Dry Media Filters
  • Built-in Bell Horn Filter Design
  • NO Check Engine Light
  • Utilizes Stock MAF Housing
  • No Surging or Other Drivability Issues
  • Wire Reinforced Silicone
  • Silicone is Designed for Smooth Air Delivery
  • Only Intakes Chosen By INFINITI USA for their Motorsport Catalog
  • Easy Install
  • No Special Tools Required
  • CARB Approved
Fitment:
2017+ INFINITI Q60 VR30 Twin Turbo
2016+ INFINITI Q50 VR30 Twin Turbo
Message me anytime for ordering details!
Vendor
Discussion Starter · #2 ·
In stock ready to ship at this time!
Vendor
These are available for pre-order directly from our website.
Vendor
Vendor
1 - 5 of 5 Posts
