Hey all, I apologize for the long post, but I can't really summarize this in a short couple paragraphs. I know some of you are going to be able to point me in the right direction:
I'll start by saying I own a modified 2014 Q50 Sport(Stillen intakes, cat delete, custom exhaust, 93o tune).
Honestly, I'm horrified after reading these forums. I feel as if I bought a lemon that isn't able to be claimed as a lemon. I bought this car used about a month ago now, and it's been bounced around in and out of shops for 3 of the 4 weeks I've owned it. Long story short, it ran amazing the first 100 miles after buying it. Shortly after that 100 miles I started noticing shifting issues - thinking back this started after getting a car wash... I think. Originally the car refused to shift past 4th gear, however, all the lower 1-4 gears were fine. I drove it this way for about 30 minutes before the car completely cut power. After a restart it seemed to drive but still continued to lack any gear above 4th. I managed to creep my way over to a rip-off chain owned auto shop to get a full diag at a total of about $300. 30 minutes later and down $300, they diagnosed it as the following: P0031 A/F Sensor(B1), O2 Sensor(B2), P0717(Input speed sensor), and told me I required a new valve body and TCM. Obviously this place quoted me a ridiculous amount for repairs so off to the Infiniti dealer I went. After dropping it off and giving the dealer an entire day to work on it, the advisor told me I needed a new valve body and o2 sensor, his quote of $2500 seemed fair so I told him to go ahead with it. 2 business day later, said advisor calls me and tells me that it wasn't actually the valve body, and that I needed a new transmission. He offered to take the valve body they put in off free of charge(thankfully) so that I could pursue other(and obviously cheaper) alternatives to their $9,000 new transmission quote. So I did; I went to a nearby AMMCO that has amazing reviews and the same owner for 16 years - really decent, honest guy. He did a free "diag?" on it and told me the same thing - I needed a new transmission. I started looking for a new trans(hard to find for the 3.7 RWD sports btw... wth) I finally found one a week later and dropped $950 into it. The next week it arrived at AMCCO and as promised, the owner installed it the same day. I get a call later that day telling me that the car is ready to roll, and after I paid for labor, I drove it off the lot. Almost instantly I knew there was something not quite right... the shifting between 3rd & 4th, and 4th & 5th gears would cause a spike in RPM's before eventually shifting into the upper gear. I thought this was strange but put if off as maybe the adaptive learning trying to learn my driving style or that it needed to get broken in a little if the used trans had sat on a shelf for a while. I drove the car for about 20 miles the day I picked it up.
Fast forward to the next day and the first 15-20 minutes of driving are symptom free. After the car warms up I end up still experiencing the weird rev bounces during gear shifts, power loss when maintaining a cruising speed, etc. but now I'm also noticing that the car isn't accelerating like it should, it was slower, louder, and seemed bogged down, which I thought was a limp mode sort of thing. I pulled over to the side of the freeway and performed an ECU reset. After turning the car back on I was able to regain power in the gears, but the gears still had the strange over-revving issue. Later that day I noticed that whenever the car was at around 60 MPH(4-5th gear) the tachometer was all wacky. It would sit at around 2k RPM and then it would quickly dip to 800 RPM(almost like it was idling) before eventually upshifting or downshifting depending on if I was accelerating or decelerating. At this point I had no choice but to bring it to AutoZone to get it scanned. After scanning it they mentioned a P1743 code being thrown - which is a code for gear ratio issues with the A/T trying to turn into 7th gear but failing. The employee tried eluding to it being a TCM issue. On the way home for the scan I tried to shift it over to manual to see if I could manually shift into 7th gear - didn't happen. I could shift into it but I had no luck with any kind of power, just RPM increase. I brought it home, let it sit for about 2 hours, and then hopped back into it and drove it around. The first 15 minutes of driving were AMAZING. It was almost like nothing was wrong with it - then it started to bog down again with the same issues as before: noticeable power loss, no 7th gear. As I was bringing it back to AMMCO the check engine light finally came on, at which point I also lost my 6th gear. So now I'm currently out about $2500, a non-working 6th and 7th gear, and 3 weeks of my time spent on trying to fix this car I should be enjoying. The transmission is under warranty, so that's nice. But I have a hard time believing it's the transmission as it seems more electric related to me.
I know this is long, but if anyone like me is out there needlessly searching for a solution to an issue similar to this, hopefully this thread(and whoever helps) can provide input that is beneficial.
