What's your Q50 configuration? any pics?What the **** is the point of linking my user profile to my key if when i sit in the car, i still have to hit the **** button near my gearbox twice to get to the personal driver modes? what a freaking joke!!!!!
Q50 always defaults to standard setting anytime you restart the car and hitting the mode switch twice is normal for personal setting. That's the way it is for now?Q50 premium All wheel drive, touring package, and the 19 inch wheel package
You're right! The 1/2 second it takes to push the switch to Personal is a waste of my time - I could be taking an extra breath then. If I get in my car twice a day, that's an entire minute of my life wasted every two months. What was Infiniti thinking???What the **** is the point of linking my user profile to my key if when i sit in the car, i still have to hit the **** button near my gearbox twice to get to the personal driver modes? what a freaking joke!!!!!
How about if the driver was given the option to either retain the last setting, or revert to default.You're right! The 1/2 second it takes to push the switch to Personal is a waste of my time - I could be taking an extra breath then. If I get in my car twice a day, that's an entire minute of my life wasted every two months. What was Infiniti thinking???![]()
Sure, it would be nice, and I think it should have been that way. However, on a scale of 1 to 100, this is about a .1 in importance.How about if the driver was given the option to either retain the last setting, or revert to default.
A wise man once said "It is better to be pissed off than to be pissed on"It pisses me off everytime.
According to the manual, it will only turn on if a certain temperature is reached.Even items that are suppose to retain settings do not... I have the heated stearing wheel on auto and i need to manually turn it on everytime.
I'll be honest, I'm not familiar with the G37. Does it allow you to change the driver mode? Does it remember that setting? Does it tie the setting to the remote?I miss my G37 AWD S!
I think it would take longer to respond to the prompt on the screen than it would to simply select the Driver Mode.How about if the driver was given the option to either retain the last setting, or revert to default.
Page 3-14Is there a listing anywhere of which all settings are personalized per key ?
I don't recall seeing one in the owners manual.
Didn't know one could click that mode twice, so thank you.
It does if you have the right add-on package. There are packages that have the memory seat (there is a button on the driver's side door that allows you to select which setting), and it will tie into a key.would be nice if the key fob assigned to the driver would have memory seat.
I challenge you to find one place - advertisement, technical manual, whatever - where Infiniti promised you that the Drive Mode would be saved to a key. Just because you assume something, doesn't mean it should be provided.the point is the it was advertised to do it and it doesn't...the point is that this along with a bunch of other stuff was supposed to work in one manner and it doesn't work how they said it was going to or misled the consume
