Nice. Can you take a pic of the fuse box and where you connected it to? I want to do the same plus i need to hardwire a dash cam as well
Here's what you need to do.
First remove the floor panel.
Then remove the panel that actually covers the fuse box. Note there is a black plastic screw that you have to remove in the back. It's right above the dead pedal. Once unscrewed simply pull on the cover till it pops off.
You will need to buy a fuse tap. It is ATM LP. You should be able to find this as most car accessories stores such as AutoZone or Advance Auto Parts. (Yes I know I have 2 different fuses in this and that they should be the same. Did not have a spare 20A fuse so used what I had available)
Now select a fuse to tap into. I selected the Power Socket (highlighted in yellow).
Pull the original fuse out and put into the fuse tap. Note, you need to put a fuse in both slots. One fuse is for the tap and the other is for the original outlet that you are tapping into. Once both are fill just put back in place.
Here is where I mounted my V1 hardware. I just velcro'ed it to the side and stuffed the cables along side it.
You will need to find a ground somewhere for the V1 adapter. Here is where I connected mine to. It's just below the hood release.
Once done turn power on and test that V1 powers up along with the power outlet or whichever item you tapped into. Once verified put covers back on. Hope this helps. Let me know if you have any questions.
