What year is your car and why are you having to replace the vapor canister?Hi, I need to replace the vapor canister, maybe any of you know if the part 149505CA0A is the same as 149504GA00? Will 149504GA00 fit my car? According to the catalog, the correct part number is 149505CA0A, but I can't find it.
Good question about the why...the Car is 2018 model year based on the thread title. Guessing he has check engine light. Maybe over-filled the fuel and prematurely damaged the canister?What year is your car and why are you having to replace the vapor canister?
Could be the EVAP canister is saturated with water. Dunno.Good question about the why...the Car is 2018 model year based on the thread title. Guessing he has check engine light. Maybe over-filled the fuel and prematurely damaged the canister?
The answer is simple, I have a slightly damaged rear of the car. And unfortunately the vapor canister was broken.What year is your car and why are you having to replace the vapor canister?
