If you heard vibrating sound from your Q50 interior when you driving on a bumpy road or when a hard hitting bass from playing music, it is most likely orginate from the seat belt retention area. What I do is put a soft thin piece of material between the gap. (see pic)
You can tell if your is making the sound by tapping on the seat belt retention area. If it felt loose and sound like 2 plastic hitting each other, than you will most likely have the vibrating sound. If it felt tight when you tap it and don't hear any sound, than your is good.
If you skill enough, you probably can open the panel and work from the inside to stop the vibrating sound.
I wonder if most Q50 (or all) suffer from this or just only me.
